Metalic noise when in bumpy roads
Hi, My 2006 FEH has this issue since I purchased it used 3 years ago, I replaced all rubbers in the front suspension, shock absorbers, rack end parts complete , stabilizer bar rubbers, practicly all elements in the front suspension are new, but the noise , even though has diminished, has not dissapeared, my mechanic suggest that the only suspect remaining for loosenes is the power steering`s electric rack, and that the normal hydraulic power steering rack has and adjustment screw ( they may tend to show some small movement inside the rack and pinion due to bad road use) , but since this one is special, he does not know about any adjustment available or if any special equipment is needed, does any one has the information to check the rack and to adjust it?
Regards
Regards
scoobiesnackarff
Jun 19, 2012 01:58 PM
jeffreykime
Mar 2, 2008 06:11 PM
