MECS fail warning?
So after I got home tonight, roll into the garage, windows open, I heard a whirring/grrrring noise. I'm used to the noises it makes on EV, but this was changing pitch. Kinda reminded me of when my GPU fan was failing on my PC. So after tring to figure out where the noise was coming from (front center) I finally narrowed it down to what I assume is the MECS pump (next to the oil filter).
So is this a warning sign of it's failing? Should I just watch some SG #'s (What ones, and what is bad?) Should I have it replaced?
Mine's a 08 I bought new, just passed 37k, will be going in for an oil change soon. I have the ext warenty, will it cover it?
I'm sure after reading the wonderful post on here, I'd be capabale of DIY, but at $150+ for the pump, or $50 for ext warrenty, obviously I'd opt for cheaper.
Any other TSB's, etc I should have checked out when I go in for the oil change / pump replace?
TIA
Bryan
TIA
Bryan
That's good to know.
If it does fail, I don't think I saw an answer in the big thread, is it dead on the spot? 95% of my trips are to/from work/school all <5mi each way. If it fails, could I finish a trip? Should I keep an eye on MET? what is normal, what is bad?
Also while tracking down the noise (it was actualy hard, it was equaly loud on all sides, but could tell it was in the front), I removed the plastic hybrid cover from the plugs, founds a mouse nest next to pass side "spark plul wire' thing, what ever they are called now, and the **** thing ate the black plastic protection cover, and exposed the bare wire of one of the 2 wires inside. Any concern there? just cover with electrial tape?
If I get a better recording of the whirr/grr/wirr noise I'll post it. Hoping it was just due to the extra silent night last night, if that makes sence, it was very quiet out.
I still have the original MEC pump at 70,000 miles and I'm going to change it till it stops working. Many people have posted they hear their MEC pump went in EV in their garage, no big deal. The pump will run with the Key On without starting the engine also. Make sure the the HVAC is in the Off position so the electric heater pump is Off and not making the noise also. Any position other than Off, the heater pump will run while in EV. I keep my HVAC system in the Off position all the time to save the SoC while in EV myself.
GaryG
Thanks gary, just the wire leading to the plug, so far!
Went out today and key on, pump was running, but normal noise, not the vibrating humm from last night. HVAC was off both times. Last night you could feel the vibration like on the hood release latch, and the plastic.
Will keep an ear open to more noise.
Here's the wire & sound, made with my camera phone, so not great
Finally went today for oil change/checkup.
They said the DC-DC output is normal ( I read mid 13's). Of course the MECS pump did not make the louder humm while there, but the Hybrid tech gave me a copy of a TSB (I'll post the # soon) and said they'll replace it with a new one, but have to order it first.
Also told me I needed a fule filter replaced, they say every 20k, I'm at 38 & never did it, didn't have my book to read tho. Also said 2 tires are at 4 and 2 at 6 so will need replacing soon. Brakes are all at 8mm.
So overall pretty clean bill of health.
AArrgg I hate stearships. I get my oil changed there for 1) its still in factory warrenty, no arguments that it was done since it should be looged into their computer system 2) it's only once a year, doesn't cost that much more than DIY or other places.
I normaly don't take their upsells, you need this or that, but I did do the fule filter, as I said I didn't have my book to see the reccomended schedule, he said every 20k. Well now that I have my book, it's every 100k!!!
The TSB paper I got is #80-24-5
2005-2008 Esacpe Hybrid & 2006-2008 Mariner
Supersedes 08-15-1
Supersedes 08-15-1
Can someone with access please post the text for this TSB? TIA!
If there's not a link, I'll post a scan when I get a chance.
Cliff notes: Red triangle, code = transaxel overtemp Codes: P1A0D, P1A0F, P0A3E, P0A7C and P1A0D may also be set.
Steps: verify coolant level, pump running, if pump is not running tap it, if it starts replace, if not check voltage. if voltage is right replace pump.
