K&N Oil Filter
K&N Oil Filter
For all of you K&N filter fans:
I just got an email from K&N informing me that they now have an oil filter available for 2005-2007 Ford Escape Hybrids (and Mariners). The part number is HP-7013.
Pambolita
Pambolita
Re: K&N Oil Filter
I dont see the point of a K&N oil filter. You want the filter with the smallest holes, not the biggest. Flow rate will always remain constant because the pump power is always the same, and can easily overwhelm filter resistance. Pressure can vary with different brands because of filter resistance.
With air intakes, flow rate varies depending on filter restriction. Oil Filters are there to clean the oil and pose no further detriment. If you want a performance boost by reducing the resistance without compromising actual filtering ability, upsize the filter. If there is room in the chassis, ford filters commonly have the same interfaces.
Re: K&N Oil Filter
And flow rate is NOT constant for different oil filters. You would find a fairly significant difference in the flow rates of a K&N vs. a Purolator Pure One oil filter, for example.
Re: K&N Oil Filter
When I made that statement, I was referring to an FEH application.
If we where talking about my highly modified '87 Buick Grand National Turbo, that would be another story entirely........
~John
~John
Re: K&N Oil Filter
"Man can not live by Hybrid alone." Me....today.
