K & N Air Filter
I just received an email from K & N Filters indicating that they now have a
air filter available for the 2006 FEH (2005, also??). If you are not familiar with K & N filters, you should check out their web site. (http://www.knfilters.com) They are pricey, but can be cleaned with fluid you buy from them, also, last FOREVER if taken care of properly, and work much better than conventional filters. We have one in our other vehicle as well as having used them in past vehicles. Year Model Engine Comment Product Type Part Number Description 2006 ESCAPE HYBRID 2.3L L4 F/I All Air Filter 33-2347 NEW! Replacement Air Filter Pambolita |
Re: K & N Air Filter
Cool!! And Hi! You're almost my neighbor!
Did you know there is also a Yamaha K&N motorcycle filter that fits ( and fits well ) for the rear battery air filter? Shoot... I had the part number sitting here for a year, now lost it. Basically, seach K&N by size. Measure the size of the battery filter ( it's something like 3.5" x 5.5"x 0.5" but don't use that, measure... I'm going off a year's old memory. ). Like the others, it's washable, and will last the life of the car. $40... about twice the price of Ford's, but if you are in a dusty environment, will be well worth it. The Yamaha is about an eighth of an inch too long, but it's just rubber gasket, easily trimmed with a knife, and does not effect the seal ( which is a rubber seal, not paper like Ford's ). If you want one, and can't find the part #, I'll do back to K&N and look. -John |
I am not knocking K&Ns as I have a set installed in one of my 300ZXs as I type. But there is a great deal of controversy about them. They do flow more air than a conventional filter, but this is not a benefit if the engine is getting all the air it needs to begin with. Several studies would indicate that some applications of K&Ns pass more dirt/dust than a conventional filter. One very real problem with them is after cleaning and re-oiling. If too much oil is used fouling of the mass airflow sensor can occur. If anyone is interested in reading more go to the bobistheoilguy forum. They have sections dealing with all aspects of automotive lubrication and filtration.
Thanks for the info, Pam. I've been waiting for it to be available. I've put them in all my cars and my Harley as well.
John, if you find the part number for the rear one let us know please. GatorJ is right you need to be conservative when you re-oil, however, I've used them for years with no issues whatsoever. If you keep your vehicles a while they will pay for themselves. |
K&N filters may work fine for you. There is no doubt K&N filters flow better than paper filters. However, using a K&N filter I've experienced dust building up a ridge around the throttle plate to the point of causing a rough idle problem. Check this link on filters and dust filtration:
http://home.usadatanet.net/~jbplock/ISO5011/SPICER.htm |
I've had one in my Dodge truck since... since.... 1990! Wow! They do last forever!
I wash it twice a year and oil it very lightly... even use other light oil, and don't buy the stuff from K&N, and while fuel injected... is an older style engine though, so don't know about any complications with the FEH but don't expect any. |
Originally Posted by worthywads
I was going to print this same site. I personnally would never put a K&N filter on any of my vehicles. Dirt is bad and any benefit is only seen at the very very top rpm range which I never get near anyways. I'll continue to replace my filters every 30K with factory replacements. K&N in a dirty/dusty environment would be the worst choice unless saving money is the only concern.
As an aside, cleaning the filter 2X/year is counter-productive, they filter better when they load up a bit. Also, oiling with anything other than filter oil designed for that purpose is asking for trouble. |
1 Attachment(s)
AIRAID makes a filter similar to the K&N, but unfortunately not for our application YET. This is a picture of the two for conventional Escapes. The AIRAID is on the right, before re-oiling. Thought you might be interested in a comparison of the two. If AIRAID does produce one for the Hybrid, that's what I'll use:
Attachment 3733 |
I fully understand this. What you didn't know is, I live in a rural farming community. Dirt roads, farmland, and dust are more common than L.A. traffic jams.
I clean when they are dirty and/or full of visible debris, like grass/hay/bugs, etc.
