Interesting display with Max A/C
At 103 deg heat index I said screw the gas mileage and turned the max A/C on. I noticed while idleing at a stop sign when the ICE would normally be off the Power display showed Battery power to Traction motor to ICE. Was the electric motor assisting the engine? BTW this has the latest software for the 07 FEH as it was just flashed last week. I noticed the ICE start up is softer and my mileage is down about 1 mpg.
Re: Interesting display with Max A/C
Originally Posted by Mark E Smith
(Post 129175)
Though, if it decreases mileage, I might not be interested at all. |
Originally Posted by WaltPA
(Post 129206)
There is a software upgrade for the '07 hybrids???
Though, if it decreases mileage, I might not be interested at all. The reason you can't use a PCM program meant for an older or newer vehicle is because of changes in equipment, options etc.. An example was my '05 FEH did not come with the key coded security system because Ford had not designed the PCM program to work properly with the FEH yet. Another example was my '05 was not suppose to come with autolocks and it did. Ford was having problems with a conflict with the program, so they waited till the '06 model for a fix. Turns out I had a problem with a strong burning smell and then lost the autolock feature. The Hybrid Tech would not reprogram autolock in my vehicle, but reprogrammed the key in the ignition unlock system so I couldn't lock the doors with the keys in the ignition. When I lost autolock, I lost both systems at the same time. This is the reason I've heard that you just don't want new PCM programming unless Ford makes a program fix for a recall. I haven't heard of that yet, so don't hold your breath that reprogramming with newer software will improve anything. More than likely it would just damage the original equipment with electrical damage. If Mark had his PCM reflashed, I would hope that the "as built" program was used in my vehicle. GaryG |
Well the mileage seems to be comming back up. I think the computer has to learn the "fine tune" for my style and area/fuel. I do think they had to retrieve from Ford the as built data as I found a copy of an email from ford to the tech on how to install the download. They do have the ability to add patches or changes to certain aspects of the program to fix emmision and drivablity problems with out totally changing the "as built", it would be logical that they would include any updates when they flash a pcm.
(Post 129175)
It also occured to me to "gun the engine" (cause, you know, I'm a guy) and I found it funny that it wouldn't let me. It will rev to about 2000, but that's it. Sort of a "I'll play your silly game, but only so far" response. Perhaps someone with a scan gauge can try this and tell whether the car is using any fuel?? |
If coasting down a long hill, for example, the battery ( or more likely, regen from the wheels ) can spin the ICE so the belt can turn the A/C compressor, using zero gas in the process. This is possible, but is a rare event. Conditions have to be "just right".
:a copy and paste from your owners manual on that issue:
"You may also notice during extended downhill driving that your engine continues to run instead of shutting off. During this “engine braking”, the engine stays on, but it’s not using any fuel. You may also hear a slight whine or whistle when operating your vehicle. This is the normal operation of the electric generator in the hybrid system" 08FEH |
Yeah, check the manual. It explains that while in Max A/C and in defrost mode, the ICE will continously run. It will give you MPG like any regular ICE car because it is always on. Buit I agree the sacrifice for 100 degree weather is worth it. I do not like that in regualr A/C mode that when it goes into EV the A/C shuts off, or at least it doesnt stay cool, gets musty and humid.
After "idling" in EV mode for a while the ICE will kick on. I beleive it is too cool off the catalic converter (don;t quote me on that!). It shouldn't last too long and get back in EV shortly. Mark |
Originally Posted by Hybrid Labbett
(Post 130827)
I do not like that in regualr A/C mode that when it goes into EV the A/C shuts off, or at least it doesnt stay cool, gets musty and humid.Mark
-- Rick |
(Post 130827)
After "idling" in EV mode for a while the ICE will kick on. I beleive it is too cool off the catalic converter (don;t quote me on that!). It shouldn't last too long and get back in EV shortly. Mark One reason is simply if the battery gets drained below the minimum level...the ICE will come on to charge it. If it is cold out, the ICE may kick on to warm up the engine (and keep the CAT up to temp in order to ensure the vehicle meets emissions. If it is hot out, or if you have been using the battery alot to power the vehicle (EV mode), the ICE will come on to circulate coolant to the battery to keep the battery from heating up and going outside its ideal operating temperature range. |
