If both hybrid and regular batteries are dead, jump start won't work?
Old Nov 11, 2016 | 01:10 PM
accent2010's Avatar
Question If both hybrid and regular batteries are dead, jump start won't work?
I tried to jump start it but didn't work. Seller said the hybrid battery is dead. How to jump start it? Can the car run with a dead hybrid battery?
Updates:
I bought it and installed a new 12v battery, it started with no issue
Old Nov 12, 2016 | 07:13 AM
Slate's Avatar
Default Re: If both hybrid and regular batteries are dead, jump start won't work?
Nope. Have to replace or charge the 12 volt batt. first. This video will show what else must be done.
Old Jan 31, 2017 | 10:24 AM
accent2010's Avatar
Updates:
Installed a new 12v battery, it started with no issue
Old Jan 31, 2017 | 10:25 AM
accent2010's Avatar
And the old 12v battery won't charge with my car or my home charger. Brought it to a battery shop, they charged it and brought it to live.
Old Jan 31, 2017 | 06:44 PM
bdginmo's Avatar
Was the HVB actually dead?
Old Jan 31, 2017 | 07:57 PM
accent2010's Avatar
No, it has no issue. It turned out the seller had limited knowledge of the hybrid. A local garage told him to replace the hybrid battery that was why he sold it very cheap. It turned out the only thing it needed was a deep charge to the 12v battery.
Old Feb 2, 2017 | 05:30 PM
bdginmo's Avatar
Ah ok...that makes sense. Sounds like you got a good deal. When you finally got it running again did it go into charge recovery mode? That's where it aggressively charges the HVB and won't use the EV boost until the HVB gets back up to a normal charge.
Old Feb 4, 2017 | 08:30 PM
accent2010's Avatar
When test the SUV, I tried to jump start it using a jump starter, it didn't work. Anyway, I brought a new battery when I picked up the SUV, it started without any issues. I did try to find the jump start button showed in the youtube video but I do not see it. Maybe not all 2008 Escape Hybrid are the same?
Old Feb 7, 2017 | 05:37 AM
wptski's Avatar
Imported from Detroit
They all have to have that switch as it's part of the system.
mhpilot
48
Aug 17, 2023 11:33 AM
Danelle
Oct 8, 2013 07:59 AM
erms32
Feb 11, 2013 09:19 PM
ukrkoz
Jul 15, 2012 10:05 AM
