Forscan balancing and battery data
For months I have been working on a PATS issue that I finally resolved yesterday. Its a 2009, so I expected I would have to follow @S Keith 's recharge procedure. To my surprise, after fixing the transceiver and reprogramming the keys, it started right up and the battery codes disappeared. Now I want to use Forscan to check the battery health and run the balancing procedure if necessary. What battery specs indicate that the balancing is needed? What battery specs should be monitored and what is good? I believe I read that DEL_MOD_V should be below 0.2 - is that right? Finally, should any precautions be taken to assure that the battery is cool during the balancing procedure?
Re: Forscan balancing and battery data
Most batteries of that vintage will benefit from balancing. In some cases with a marginal battery that has a pending failure, the balancing can trigger the failure.
DEL_MOD_V is the only meaningful parameter for battery health. The RMODE_BALANCE function will not run if the battery is too hot. If A/C is fully operational, the cooling system should keep the battery cool and comfy. |
@S Keith Thank you! DEL_MOD_V is now much improved.
Originally Posted by mattbuilt1
(Post 277525)
Greg |
Originally Posted by PTTech
(Post 277603)
Can you describe for me what your PATS issue was and how you fixed it? I tried programming some extra keys to my car and recently started getting HVTB issues. I just got forscan and am trying to sort out how to use it, too.
Greg |
(Post 277604)
Go into the BCM and display all parameters. Post results here.
(WARN) [13:25:03.364] DTCs in TCM: P1260-FF, P0562-FF (WARN) [13:25:03.419] DTCs in PCM: P0128-FF, P1000-FF (OK) [13:25:31.007] Successful DTC reset, DTCs will be read now... (WARN) [13:25:31.065] DTCs in PCM: P1000-FF (OK) [13:34:58.951] Successful DTC reset, DTCs will be read now... (WARN) [13:34:59.027] DTCs in PCM: P1000-FF (WARN) [13:52:59.786] DTCs in PCM: P1000-FF (WARN) [13:53:00.045] DTCs in BCM: P0ABF-20, C1862-20 (WARN) [13:53:29.155] DTCs in PCM: P1000-FF (WARN) [13:53:29.365] DTCs in BCM: P0ABF-20, C1862-20 |
P1260 Theft Detected, Vehicle Immobilized
DTC C1862 — Contactor Circuit Failure, which may be triggered by a IFS switch open circuit. If you haven't already done so, there are two inertia fuel shutoff (IFS) switches tripped in the event of an impact. Low probability as ther eis a IFS code as well that is not present. I don't recall where they are. Extremely important that the 12V is both healthy AND fully charged. Simply having a new 12V is not enough. The 12V must be either load tested or put on a digital tester to confirm health and fully charged. First step is to clear codes and see which ones return. The P1000 suggests you have as that's a "not ready" code for emissions check. Recommend you sign up at: https://www.motorcraftservice.com Can get access to all manuals for 2 days for $25. You can also get BISHKO manuals from ebay for about $50. |
(Post 277606)
First step is to clear codes and see which ones return. The P1000 suggests you have as that's a "not ready" code for emissions check. Recommend you sign up at: https://www.motorcraftservice.com Can get access to all manuals for 2 days for $25. You can also get BISHKO manuals from ebay for about $50. I have cleared the codes and the P1000 code is the only one present now. I ran the rebalance once and it didn't seem to help much. Real time SOC doesn't get above about 45% and Del Mod V is around .38 volts. Do you think my battery is toast? It was driving and working well until recently and now it seems like the HVTB is self-discharging overnight and I've had to do the jump start to get it to charge up again. BTW, I've let the car sit for 15 minutes on and parked and the engine will cycle on and off. Reading the SOC right now it is almost 53% and the Del Mod V is bouncing between .31 and .25. Greg |
SoC tends to live in the 45-55% range very generally. It is most efficient in this range.
The RMODE_BALANCE function runs it up to about 85%. You can hear it transition from loaded charging to unloaded spinning (it drives the engine to discharge the battery back into the operating range). I like to try and catch it, terminate it early and check the SoC/DEL_MOD_V (DMV) in the BCM table. A DMV value of .38 is a strong sign of weak or failing cells. If you put it in "N" and discharge it to lower SoC with electrical loads, the DMV will likely increase. Additional confirmation of a failing battery. As you cycle and use the battery, it is possible to narrow the DEL_MOD_V range. Increases following periods of sitting indicate excessive and uneven self-discharge (battery failure). It is possible that the battery is simply imbalanced, and a grid charge to true 100% would help. It could also push a marginal battery completely over the edge into full cell failure. |
(Post 277609)
| All times are GMT -7. The time now is 08:17 AM. |
