Are FEH dipsticks Accurate?
Old Jan 20, 2014 | 10:56 AM
TeddyB4x4's Avatar
Default Are FEH dipsticks Accurate?
Getting ready to fill the last cavity with synthetic {crankcase}; and noticed the variation of fills from 4-4 1/2 qts.: and the twist dipstick in discussions https://www.greenhybrid.com/discuss/...question-9886/
Has anyone noticed if you check the oil after sitting it reads low [which I was taught to be , and always found the most accurate ] , but if I wipe it off reinsert and then check it it's full???
Old Jan 20, 2014 | 11:43 AM
econoline's Avatar
Default Re: Are FEH dipsticks Accurate?
When the Ford dealer was doing my oil changes the FEH would come back filled to the Max line or slightly above, and 1/2 qt of unused oil in the container. I change my own now and 4.0 qts fills to halfway between Min and Max, that's with a filter change.
Supposedly the most accurate way to check oil level is to remove the dipstick, wipe it, and leave it out for a couple of minutes or longer. This allows any oil on the dip tube walls to drain. Then insert dipstick and immediately check the level. Anyway, that's what I do.
Old Jan 20, 2014 | 12:16 PM
I've found the dipstick shows low after running and cooling down. Its as if a slight pressure builds in the tube holding the level down. So what I began doing years ago is to pull the dipstick, wait a few seconds, the reinsert it and pull & read it. That gives me an accurate level.
Old Jan 22, 2014 | 10:50 AM
TeddyB4x4's Avatar
Those both sound good, I'll do That as soon as we get a warmer dry day here, LOL!
Old Feb 5, 2014 | 03:50 PM
I always put in 4 quarts.
Remember the correct fill is anywhere between the two marks.
Not the top of the "full" mark.
I have no leaks (on the pavement) and usually never have to add any more, but I check it every 2-3 months. Then and only then would I ever add more.
I use Mobil 1 and go one year or 15,000 miles between changes.
A couple years ago I sent a used sample to the lab.
Lab said oil was still good at 15,000 and I could easily go 20,000 miles in the future but I usually don't.
-John
kluken
Aug 8, 2006 11:09 AM
helicraz
Website Questions & Input
10
Jul 24, 2006 04:07 PM
lars-ss
Hybrid & Related News
Nov 23, 2005 04:52 AM
