"Energy flow function" and "Fuel economy function" buttons not working
Old Nov 2, 2013 | 12:44 PM
leetramp's Avatar
Exclamation "Energy flow function" and "Fuel economy function" buttons not working
Greetings,
I have a 2007 Ford Escape Hybrid with the navigation system. The one rocker switch/button that displays "Energy flow function" and "Fuel economy function" suddenly stopped working. All the other buttons on the nav system (radio map, nav, CD, etc.) work fine, but when I click either sides of the fuel/energy button, nothing happens (whatever was up on the screen stays there).
I did an internet search, and found someone else with the same problem, but the only answer there was "take it to the dealer."
Has anyone experienced this problem? Any suggestions as to what the solution might be? At this point, my wife and I don't think it's worth paying the dealer to fix it, as we both just sort of use it "for fun," and it is no longer altering our driving habits .
Thanks for any tips/suggestions.
Old Nov 5, 2013 | 05:20 PM
LeapinLar's Avatar
Default Re: "Energy flow function" and "Fuel economy function" buttons not working
My 2007 FEH had exactly the same problem when I bought it a few months ago. It is caused by a failed module under the glove box. It is called the ACP (Audio Control Protocol) Module. It converts the OBDII signals to a form the Nav radio can use. I just bought a new one from my Ford dealership (~$200) and installed it myself. It just plugs into two cables. Works perfectly now.
Old Nov 5, 2013 | 08:54 PM
leetramp's Avatar
LeapinLar,
Thanks for the tip. I'll probably pass on the $200 purchase right now; if I'm going to spend that much I'll just get a ScanGuage (my last one was stolen ). The rest of the device works just fine.
Old Nov 6, 2013 | 05:05 AM
pintuhs's Avatar
Second Hand Cars
I would like to suggest, just check the wiring of navigation system of your ford escape car to your nearest garage or any lettered mechanic. I'm sure he can solve this proble without spending more money.
Old Nov 6, 2013 | 08:10 AM
LeapinLar's Avatar
Originally Posted by leetramp
LeapinLar,
It could also be the wiring to and from the module. Look at TSB 06-5-15. So you could hire a mechanic to trace the wiring like the last user recommended, but that is not exactly free either. Or you could do it yourself.
Not having it work when I bought the rig, I wanted to see what it said. And I am glad I fixed it. I learned a lot about how the vehicle operates, with it being in hybrid mode most of the time.
Old Jan 25, 2022 | 03:19 PM
bradleydahl's Avatar
do you happen to have a part number for the ACP module and or a picture of the specific part? Thanks
Old Jan 26, 2022 | 10:22 AM
Ford Parts Giant is an excellent resource for locating part numbers, especially if you enter your VIN.
https://www.fordpartsgiant.com/2008-...rid-parts.html
Also, you can subscribe to the Ford Motorcraft manuals site for $24.99 / 72 hours and that part should be in there.
https://www.motorcraftservice.com/Home/SetCountry
cje2310
Dec 1, 2011 10:37 PM
MDemeran
Jan 31, 2010 04:04 AM
njaeger
Mercury Mariner Hybrid
Sep 9, 2009 09:30 AM
Escape_from_Hanover
Dec 16, 2008 07:54 AM
GNiel9
Toyota Highlander Hybrid
Nov 26, 2007 10:22 PM
