Change Oil Warning
Hello all,
I picked up my Escape after having it serviced last week. Apparently the shop forgot to reset the "change oil" warning indicator as it came on today. I'm supposed to go on a trip tomorrow and was wondering if this would cause a problem? The warning doesn't bother me, I just want to make sure nothing shuts down on me.
Go into the message center and toggle down to "System Check". Press "SET" and the first screen is your oil life counter - it should have 0% on it. While this screen is on, press and hold the set button and it should reset to 100%.
Hope this helps.
Hope this helps.
Hello all,
![Sad](https://electricvehicleforums.com/forums/images/smilies/emotikons/sad.gif)
I wrote about it, in their service quality post card.
Its in your manual... it represents 10,000 miles or 12months... whichever comes first. Standard maintenance interval for the engine which is NOT on all the time and doesn't tally up hours of use on oil idling like a normal engine.
Anybody know how to change the oil change % to something other than 100% when resetting ? I use the motocraft synthetic blend oil, but I still don't trust waiting 10k for an oil change. I'd rather change the % to 50% and go 5k miles.
I got my 10% oil life remaining warning last night after 8976 miles (on an July born '08 FEH) so it doesn't appear to be a straight calculation off the odometer or calendar.
...unless Ford is factoring in miles done while traveling in reverse
![Smile](https://electricvehicleforums.com/forums/images/smilies/emotikons/smile.gif)
![Red face](https://electricvehicleforums.com/forums/images/icons/icon11.gif)
![Teeth](https://electricvehicleforums.com/forums/images/smilies/emotikons/teeth.gif)
Or there were 24 miles put on it that somehow weren't accounted for in the odometer....perhaps it was rolled back by the dealer.
Yeah, 24 out of 8976 seems pretty good to me too.
![Omg](https://electricvehicleforums.com/forums/images/smilies/emotikons/omg.gif)
