Cabin Heater Pump - Part?
Hello,
So, I bought my 2006 FEH last summer, and on a hot day I noticed found out the hard way that my MECS pump was bad. Thanks to the instructions on these forums... that has been resolved! And for $400 less than the dealer wanted. Well, now that we're averaging -20 Celsius (-4 F) temperatures where I am, I've noticed that my Cabin Heater Pump definitely isn't working either. With the ICE off there's no heat. I thought I could put up with it but I can't... and my wife has definitely made it clear to me I need this situation fixed! :omg: So, I've been looking around and it sems the the part number for the Cabin Heater Pump is: #6M6Z18D473AA, can someone confirm if that is the part I need to replace? In searching for that part it appears so... however I found that this part may also be related / correct to use to repair my 'heat-when-the-ICE-is-off' issue: Bosch 96163 Is this correct? Can I use either part? Are they the same part? I'm also looking for instructions of replacing this part, I tried to find them in these forums (since the MECS replacement instructions I found before were awesome!) but I can't seem to see if anyone else has replaced this heater part pump themselves! Thanks for any help you can provide! |
Re: Cabin Heater Pump - Part?
Bosch 96163 looks like the mechanical engine water pump
Ah, yes. Thanks for that... it looks like that's correct.
However, I just found this part number which looks like it is the correct part#: #8M6Z-18D473-A The above looks quite similar to the original that I had looked at previously: #6M6Z-18D473-AA Not being a car guy, are both the above parts the same, or similar? Would either one work for me? Thanks. |
I realize I'm only talking to myself here, but thought it might be nice in case anyone else is looking for the same info in the future.
I called Ford and the part seems like it is the same, just different countries. USA: #8M6Z-18D473-A - Quoted at $270.00 CAD Canada: #6M6Z-18D473-AA - Quoted at $258.00 CAD |
$116 from silverstatefordparts.com
Originally Posted by econoline
(Post 245964)
And considering Ford was saying 10 days for delivery I should get it around the same time, if not sooner. Now I just have to get it installed. I would try myself but it seems it's much more involved than the MECS pump I did this past summer... (Anyone have a service manual from which they can share this procedure? ;) ) EDIT - Has Speedy Auto install the pump for $218.00 including new coolant. All seems good now! Total cost (Part: $111, Shipping: $48, Install: $218 - Total $377) |
