Black plastic containter behind driver fog light?
Old Mar 31, 2013 | 12:44 PM
Deezul's Avatar
Default Black plastic containter behind driver fog light?
I had the replace the fog light on my MMH. The shop manual was incorrect regarding the fog lamp, saying the lamp was held in place by 4 screws. It's 3, and it's not screws but the adjusters that hold it. Anyway, I removed a black plastic container that looked like it was a catch for water draining from somewhere. There was a hole at the bottom, so whatever it did catch would drain off. What is it for?
Old Apr 3, 2013 | 08:25 AM
rdinatal's Avatar
Default Re: Black plastic containter behind driver fog light?
Drivers side?
If so then it's probably part of the air intake. The drain hole is for any water that get's pushed into the intake opening. The filter box has the same type of hole.
-R
Old Apr 4, 2013 | 01:50 PM
Deezul's Avatar
Yes, that's it. I've just never seen that below an air filter. Seems like a bit of overkill, instead of just a hose or something.
Old Apr 5, 2013 | 04:21 PM
travelover's Avatar
Feral Engineer
It is a tuned Helmholtz resonator - it makes the induction noise quieter.
http://physics.kenyon.edu/EarlyAppar...Resonator.html
Old Apr 5, 2013 | 06:33 PM
econoline's Avatar
Good catch. Never knew about those.
cak615
Oct 28, 2013 08:11 PM
SadCarTime
Jul 9, 2012 08:05 AM
09altimahybrid
Jul 26, 2010 06:40 PM
Saith
Feb 10, 2006 01:53 PM
cdbrow1
Jul 19, 2005 08:35 AM
