Battery heater
Has anyone hooked up a heater blower to the HV battery duct work? I envision something similar to a hair dryer to plug into household 110v, similar to a EBH only for the battery. Seems like it would enable a quicker transition into deeper hybrid mode.
Re: Battery heater
2 Attachment(s)
There is a battery heater inside the hybrid battery box:
Attachment 2932 This heater had a wire to connected to the engine block heater (option 41H) for the 05-07 vehicles. Early in the 2008 production run, Ford eliminated the the wired connection to this hybrid battery heater as shown in the photo below: Attachment 2933 Combining a timing device with the plug in engine block heater can enable one to start the vehicle with the hybrid battery temperature around 60F and engine coolant at 100F. |
Re: Battery heater
I checked mine and the wire is there. Do you know ho long to leave it plugged in at 20F say?
I already have the block heater that I have on for 3 hrs. Do you know a good source for the transformer that plugs into the battery heater? |
Re: Battery heater
Originally Posted by subdewd
(Post 232599)
Re: Battery heater
Should have been more specific, i installed an aftermarket heater from NAPA it works ok, but doesn't have the battery charger or pig tail. I just did a quick search and found a place that supposedly has them.
$113+ . seems high, I'll check with my local dealer. Have you found it effective? It's frustrating having a hybrid and not getting full advantage of it 2 months of the year. I did do the grill block and that helps immensely. Thanks for your help |
Re: Battery heater
One more quick question, did you actually measure the current when it was plugged in? For the charger itself that is. thanks again
Re: Battery heater
1 Attachment(s)
This is option 41H:
Attachment 2931 I do not know what components from this photo you need on your vehicle. |
Re: Battery heater
(Post 232603)
Re: Battery heater
Ok, so I ordered a 4A 24vdc battery charger, total cost like $30, I know it doesn't have the proper
connectors but it shouldn't be a big deal. Just couldn't see spending 4 times that. Will keep board posted, |
Re: Battery heater
(Post 232610)
connectors but it shouldn't be a big deal. Just couldn't see spending 4 times that. Will keep board posted, The good news is, in my 2005 at least, the HV battery has some sort of built-in thermostat. Heater comes on at 50'F and anything below, and shuts off, or won't go on at 60'F or anything above. For the record, I'm sure the Ford OEM transformer was pretty cheap. It was the custom cable that cost an arm and a leg, so you'll be fine with a cut & splice. |
| All times are GMT -7. The time now is 07:34 AM. |
