2009 FEH specs
Old Aug 8, 2008 | 08:39 PM
mostel's Avatar
Default 2009 FEH specs
Anyone have a link to model year 2009 FEH? Thanks in advance.
Old Aug 9, 2008 | 08:10 AM
GaryG's Avatar
Default Re: 2009 FEH specs
Try this link:
http://www.carsdirect.com/2009/ford/escape_hybrid/specs
Old Aug 9, 2008 | 10:24 AM
Green Lantern's Avatar
Originally Posted by GaryG
Oh my lord that site is cwazy
It would be nice if they actually read what they posted before they actually put it out there:
"Buying a 2009 Ford Escape Hybrid
Purchasing an older vehicle, such as the 2009 Ford Escape Hybrid, makes good financial sense. You're able to avoid the steep depreciation rates that occur with brand new vehicles. This essentially gives you the advantage of getting a 2009 Ford Escape Hybrid for less money than when it was new. If the 2009 Ford Escape Hybrid was properly maintained, you also have a good chance of steering clear of problems that would have developed when the car was new....When you're ready to purchase a 2009 Ford Escape Hybrid, be sure to check out our section on used cars. We have listings for thousands of models so it should be easy for you to find a 2009 Ford Escape Hybrid that meets your needs. "
Old Aug 10, 2008 | 08:09 AM
mostel's Avatar
I believe the 09 now has advanced trac vehicle stability control standard. I don't think that link says that though. Anyone know?
Old Aug 10, 2008 | 10:38 AM
GaryG's Avatar
Yes, my '09 FEH has Electronic Stability Control and RSC according to the owners manual. It is now standard on the FEH/MMH and has been standard on the gas Escape. There is a switch below the Nav sys to turn off ESC/RSC so power can be provided by the engine if you get stuck and need to spin the wheels.
GaryG
Old Aug 12, 2008 | 10:22 AM
leoashton's Avatar
I looked at an 09 on sunday and noticed the following differences on the particular model I was looking at from the 08s (in addition to engine/cover & RSC):
Ability to get Limited trim and other options instead of just hybrid packages (this one had painted grill, no chrome on front.)
Cloth seats are the darker "grey" color, including the plastic frame (not 2-tone, didn't like the look as well, but it will probably be MUCH easier to maintain).
Interior door panels have padded dark grey cloth in center above arm rests.
Wheel spoilers in front of the rear wheels are smaller than I expected.
Front spoiler below the bumper cover is quite a bit different.
Tail pipe sticks out from the bumper instead of mostly concealed.
Button for the sunroof may have auto-close in addition to auto-open (says auto), and is recessed.
RSC button in bottom center of dash as GaryG says, between USB/Sync port and power port.
Obnoxious (to me anyway) Microsoft Sync badge above gear shift.
No Escape badge on side, Hybrid logo and lettering similar to 07s and earlier on front doors (I want mine now).
Michelin Tires.
Invisible Shield/Paint Protection lower right hand side of rear doors.
Front Passenger "Panic" grab handle.
hugoland
Sep 1, 2009 09:06 AM
Eskrimast1
Jan 9, 2006 04:10 AM
Jason
Website Questions & Input
Nov 22, 2005 06:55 PM
babsrocks
Apr 12, 2005 02:34 PM
xcel
Jan 25, 2005 01:11 PM
