2006 FEH completely dead
Old Dec 18, 2016 | 08:35 AM
joecole's Avatar
Default 2006 FEH completely dead
As in nothing. Not even the odometer shows up. no headlights, no power anything. The battery reads as 12.45v which is slightly low but it should at least give me something.
It sounds similar to this https://www.greenhybrid.com/forums/f...ed-help-28856/
I'm going to test this out today. Does anyone know what relay they ae referring to and where to find it?
Old Dec 19, 2016 | 11:46 AM
08escapehybrid's Avatar
Default Re: 2006 FEH completely dead
I believe on the 06 the jump start button is inside the driver compartment near where your feet are when you are cruising for a while.
Old Dec 19, 2016 | 03:35 PM
joecole's Avatar
So no... we tried the jump start button and it did not illuminate.
When I say the car was completely dead I mean COMPLETELY dead. No signs of power anywhere. It was as if the 12v battery had been removed.
I'm curious if there is a relay somewhere that completely shuts off the 12v system.
Interesting update:
So yesterday I went back to the car to test jumping the battery pack to the frame with a start kit. When I arrived at the car it had magically sprung back to life and the flashers were going. This was draining the battery so a simple jump was able to get the car going and it's behaved normally for the past day and a half.
Old Dec 19, 2016 | 03:44 PM
There isn't one that I am aware of. It almost sounds like it could be either corrosion at the battery posts, a loose connection there or you could have a ground that came off somewhere or is overly corroded. Has it acted up in the past or is this the first time?
So it is dead dead? No clicks, no lights, nothing?
Old Dec 19, 2016 | 03:55 PM
joecole's Avatar
Yes DEAD.
No clicks, no lights, no locks, no jump start button. No interior lights. Anything that would be powered is 100% gone.
So the battery terminals look fine. No apparent corrosion there. I check the voltage between the battery and the main in on the fuse box as it was one thing I could get at easily without a diagram or tracking something down somewhere. Silly me I didn't check the voltage or continuity from frame to the negative terminal.
Any idea where the ground wire hits the frame on this vehicle?
Old Dec 19, 2016 | 03:58 PM
Eh, I would just dig into the frame a bit with your continuity meter and then see if you have any continuity between the frame and the negative battery terminal.
jayw_TCH
Jan 31, 2011 06:06 PM
Eric554Park
Aug 9, 2010 07:42 AM
tbone526
Off Topic
Sep 19, 2008 08:09 AM
Heavymetal
Mar 29, 2008 05:07 PM
caymandiver75
Oct 8, 2005 03:55 PM
