2006 Escape, no motor (ac/pump?) runs at initial startup
Hey all,
I need some help diagnosing my problem... It used to be as soon as I turned the key to run, it seemed that a fan in the back would start. Maybe it was a pump? Well this is my wife's car and I don't drive it much but now when I drove it, I no longer get that at start up and it has to be driven a LONG time before going into battery mode. I've read about the MECS pump, blend door actuator, cooling fans... I don't know what SHOULD be happening and where to begin diagnosis... Help a guy out! Thanks! |
Re: 2006 Escape, no motor (ac/pump?) runs at initial startup
BTW 51,000 miles and no check engine lights etc have ever come on, but it does not appear to be running correctly...
Originally Posted by ddderek
(Post 248383)
Gary |
OK, I could buy that except for the fact that I used to hear a motor running when I turned the ignition to run... even if the car was not started, this fan, or pump, or some motor in the back would start running for a few seconds... Now it is silent. I always thought it was a cooling fan or something to evacuate the fumes from the HV battery back there...
As far as going into EV mode, it takes a long time in the city if at all but driving it to work today it finally did after getting off the highway and a 20 minute drive. That would go along with your t-stat analysis... But what about the motor at start up??? Does yours make that noise at start up? Turning the key to run without actually starting? |
(Post 248387)
As far as going into EV mode, it takes a long time in the city if at all but driving it to work today it finally did after getting off the highway and a 20 minute drive. That would go along with your t-stat analysis... But what about the motor at start up??? Does yours make that noise at start up? Turning the key to run without actually starting? Gary |
Cabin AC is cold and strong, NOTHING runs when the key is on but not started... maybe the battery fans are bad and that is causing the problem? Why would it go into EV mode after a 20 minute trip on the highway though? I would think if the battery fans were bad I'd get a check engine light?
And will the dealer check for codes without a charge? I know I don't want them to fix it at their prices??? |
1 Attachment(s)
(Post 248390)
1 Attachment(s)
This may or may not help understand the hybrid battery pack:
Attachment 2599 |
ok, here's where I'm at... I just got the car back, (numerous family drivers), I started the car to let it run for 10 minutes as Gary suggested, the top (smaller) hose to the t-stat got warm the large (bottom) hose stayed cold, then at about 7-9 minutes? didn't look exactly, it went into electric. When it did, I could hear a whineing like air being let out of a balloon on the lower driver side and tracing it out, that appears to be a small pump, the MECS Pump? with two hoses attached and the hoses felt like water was being pumped through them. Sounds like it may be ready to be replaced.
Now the questions: There is another slightly larger pump on the passenger side under there also with two hoses, what is that? Also through all of this, NEITHER radiator fan came on and the large hose to the t-stat never got warm... when should these fans come on?? I will check on the back battery fans, but one thing about back there, I did take off the filter cover before with it running and that door below the filter was closed and never opened up? Should that open immediately? Is that the blend door problem? Thanks everyone for the help!! I hope to avoid the Stealership! |
(Post 248394)
Now the questions: There is another slightly larger pump on the passenger side under there also with two hoses, what is that? Also through all of this, NEITHER radiator fan came on and the large hose to the t-stat never got warm... when should these fans come on?? I will check on the back battery fans, but one thing about back there, I did take off the filter cover before with it running and that door below the filter was closed and never opened up? Should that open immediately? Is that the blend door problem? Thanks everyone for the help!! I hope to avoid the Stealership! The radiator fans should come ON only when needed to cool the coolant in the radiator when hot. The battery filter door is closed most of the time to bring up temperature in a cold battery. It's not a sign of a blend door problem, only a trouble light will come ON for that. Gary |
