2006 Escape Hybrid, driver door lock doesnt unlock after batter replaced
I had the 12 volt battery replaced by the dealer the other day and now my drivers door wont unlock with the fob or the electric locks inside. It will lock though. I am tyring to find out if anyone has seen this before so i can complain to the dealership about being charged for it. I can not prove the issue wasnt there before they replaced the battery.
Re: 2006 Escape Hybrid, driver door lock doesnt unlock after batter replaced
Originally Posted by vader83
(Post 227853)
Take your FEH back and I'm sure they will take care of it for free. You will need both of your fobs for them to reprogram them again. They told me it would take a hour to fix it. I need to still get it done. GaryG |
It isnt just the fob that doesnt work though. It is also when you physically press the unlock in the car that it doesnt unlock.
I think resetting the fob is easy, it is just a sequence that i am sure you can find online. I used to know how to do it, but it has been too long since i needed to. I did it for my 03 escape a few years back. |
I just bought a new fob (eBay). The programming is child's (pre-fifth grader) play.
Turn the ignition to ON (not start). Then, turn it OFF and ON EIGHT times in less that 20 seconds. (you will hear and see some indication that you're in programming mode) Then push ANY button on the FOB (you'll see and hear the same thing again). DONE. If you have more FOB's then push any button on each of them too (within 5 seconds, each) Piece of cake! |
this exact thing happened to me this week with my 2006 ford escape. i replaced the battery two days ago, and the driver's side door does not unlock with the key fob or with the electrical lock button. so, were you able to find out what the answer is? (noticing a pattern...)
Originally Posted by bjjb
(Post 229041)
My problem ended up to be chlorine that damaged my carpet and seats also got on my hands and ended up corroding my fob inside.
The problem I'm hearing here sounds like the Smart Junction box (SJB) or bad fuse. I'd check all the fuses in the SJB and the fuses in the Battery Junction Box (BJB) first. GaryG |
Did anyone who was experiencing this problem get it resolved?
I'm having the exact same symptoms. 12V battery died today. Just replaced it. Everything seems fine except the power unlock of the driver's door, either from the door switch or the fob. I can unlock manually, but power unlock of just that door is not working. Power lock works fine. I did turn up the following via Google: http://www.justanswer.com/ford/52182...rd-escape.html and http://www.justanswer.com/ford/53fhs...pe-hybrid.html |
You might try reprogramming the Power Door Lock/Unlock features per the owner's manual. Maybe part of that programming was lost when the battery was replaced.
Originally Posted by econoline
(Post 244101)
Web consensus seems to be an SJB problem due to a power spike when changing the battery. Whether it just needs to be reprogrammed by the dealer or replaced is the $10K question. |
| All times are GMT -7. The time now is 02:02 AM. |
