2006 Escape Dies While Driving
Old Oct 28, 2013 | 07:46 AM
Rupejeremy's Avatar
Default 2006 Escape Dies While Driving
My 2006 Ford Escape Hybrid motor will die without warning while driving or setting in park. All the information center will tell you is to "safely pull over" and the "Power" indicator light will come on. The car will restart and run for a few minutes but will die again and eventually will not even re-start. I let the car set for a day and the car was fine to drive for 2 days and then I started having the problem again. I am suspicious of the battery getting week, but was uncertain if I should change the 12 volt battery or if the high voltage battery was actually the one that started the car. Or, if the battery was even the issue.
Any information anyone has on this would be helpful because I know very little about the operation of Hybrids.
Thanks in advance
Old Oct 28, 2013 | 08:23 AM
dukenilnil's Avatar
Default Re: 2006 Escape Dies While Driving
Check this thread.
https://www.greenhybrid.com/discuss/...ely-now-11900/
Old Oct 28, 2013 | 04:37 PM
GatorJ's Avatar
The FIRST thing to do is have your FEH scanned by a mechanic with a scan tool capable of reading Ford's proprietary codes. There are several conditions that cause the problems you are experiencing.
Old Oct 28, 2013 | 05:04 PM
84GT Ragtop's Avatar
Yeah, don't just throw money at it till you know what the codes point toward. I had a 12V battery issue code and a new battery solved it for me, but many others have the MECS pump crap out on them when they get the SSN issue. Still others may have the battery cooling fans fail, or....?
And FYI most generic code readers will NOT show the various Ford-specific DTCs from the various modules so don't expect the guys at Pepboys to find anything. Your best bet is having a Ford dealer pull codes from all the modules.
Old Oct 29, 2013 | 04:23 AM
Rupejeremy's Avatar
Thank you both for the input. It has helped me out and I will get back with you in the future to inform you of the repairs.
LeeS
Sep 1, 2011 03:44 AM
smallgulp
Apr 20, 2007 04:09 PM
bwilson4web
Mar 21, 2006 03:12 PM
masgian
Feb 9, 2006 08:18 PM
ice weasel
Jun 14, 2005 09:19 AM
