2005 Escape steering question
Old Jul 9, 2012 | 09:01 AM
dae06's Avatar
Default 2005 Escape steering question
This vehicle to me is hard to drive. It doesn't seem to "self center" itself after turning the steering wheel. If I turn the steering wheel 5° to the right (while moving) and let go of the steering wheel, it will keep taking the 5° turn. I'm used to having the steering wheel turn back to straight. Is there an adjustment for this?
Old Jul 12, 2012 | 08:49 AM
dae06's Avatar
Default Re: 2005 Escape steering question
Anyone?
Old Jul 12, 2012 | 02:26 PM
FjordHybrid's Avatar
Caster is out of spec probably. Would take it in to an alignment shop and see what they say.
Old Jul 14, 2012 | 08:18 PM
Keep in mind Ford's designed the Escape with a "toe-in" alignment. This will wear the inside of your front tires faster than normal. You should re-aligned the vehicle into a neutral position as I did and some others have.
gc77584
Jan 9, 2020 04:20 PM
neo_isaac22
Jun 16, 2013 04:52 AM
baceball6
Dec 22, 2009 10:51 AM
MagneticPearl06
Feb 6, 2006 09:01 PM
wxhall
May 14, 2005 12:47 AM
