10-12 mpg city, 27 fwy, whats wrong?
Old Aug 1, 2019 | 04:25 AM
notsonerdy's Avatar
Default 10-12 mpg city, 27 fwy, whats wrong?
anyone that has found solutions or suggest solutions, I appreciate the input
Old Aug 1, 2019 | 10:31 PM
notsonerdy's Avatar
Default Re: 10-12 mpg city, 27 fwy, whats wrong?
update, now it runs on "ev"/ battery, but only for a short time - city mpg has gotten better, but I feel there is still something wrong. no check lights/ codes
Old Aug 2, 2019 | 04:42 AM
Rex B's Avatar
Search the archives. Most common issues are thermostat, rear blend door, rear air filter, failed battery fans.
Old Aug 15, 2019 | 03:30 PM
notsonerdy's Avatar
I changed the battery, seems to have slightly better mpg @~15 city now. changing fuel filter next
Old Sep 2, 2019 | 12:51 PM
notsonerdy's Avatar
changed spark plugs, engine response is stronger averaging ~18/19 city 30 fwy
Old Sep 2, 2019 | 02:09 PM
econoline's Avatar
What model year is your FEH? How many miles are on it now?
Old Sep 5, 2019 | 12:33 AM
notsonerdy's Avatar
206, mariner ~180k miles. I changed the rear filter, it looked oem and probably never changed - the hybrid battery worked a lot better. I also changed the coil packs which provided immediate low end response, before it was bogging. it now get 27 fwy, 31 city. I still think it can perform better
Old Sep 6, 2019 | 07:18 AM
Rex B's Avatar
Interesting. I figured a coil pack was either all good or dead.
I may try that. Coil packs are cheap and easy to replace.
Old Sep 10, 2019 | 10:53 PM
accent2010's Avatar
Is your a/c working good?
Old Sep 22, 2019 | 10:43 PM
notsonerdy's Avatar
a/c works great. I've notice a slight rough idle. after doing research, it suggests i change the fpr. i'll be changing that next
