08 Speaker Replacement
I'm a newbie (just got my 08 AWD yesterday) and wanted to ask about replacing the factory door speakers.
Is it easy enough to do myself? Are there some good instructions anywhere online? I've been googling a lot and haven't found much. Thanks, Todd |
Re: 08 Speaker Replacement
Mine is an 06, but it took me probably five minutes to remove each front door panel & the rears are even easier.
The only problem you may have is, the plastic clips that hold the panel on may break & require replacement (I bought extras for that reason). ~John |
Thanks. Nice mods.
Which retainer clips do you recommend? After a quick search, it looks like there's a lot of different kinds. |
I'm pretty sure these are the right ones, but I would have to check at home to be sure (I am at work)
http://cgi.ebay.com/ebaymotors/25-Do...spagenameZWDVW ~John |
Originally Posted by tommyball
(Post 133593)
Is it easy enough to do myself? Are there some good instructions anywhere online? I've been googling a lot and haven't found much. Thanks, Todd It'll be interesting to see if aftermarket speakers are significantly better, especially if you don't change the location of tweeters (in door panels, along with the midrange). |
Originally Posted by jmorton10
(Post 133727)
Originally Posted by rb1
(Post 133730)
Yea, that is a horrible acoustic location for the tweeters, I would certainly add component speaker & move the tweeters up where they're supposed to be if I changed the speakers in an 08...... ~John |
Originally Posted by TeeSter
(Post 133740)
John..... Mines an '06 too. What speakers did you use? Did you have to modify anything in the door panel? Was it a big difference? Knowing typical factory speakers I imagine it was a big difference.
It made a huge difference in sound quality, but I added a killer 4 channel MTX AMP & Dynamat Extreme at the same time also (along with my Eclipse NAV/DVD head unit) ~John |
(Post 133741)
~John Since you also changed your stereo from the factory to the Eclipse when you changed the speakers, a part of the superior performance might also be from better electronics in the new stereo, right? |
Well I got the AWD base model and had planned on installing a new head unit and speakers but after finally getting my car (I only test drove models with the Nav System) I want to wait to see if Crutchfield comes out with any 08 installation kits. The stereo is fairly close to the climate controls and I don't feel comfortable fabricating a new panel just yet...so... I'll just start with the speakers.
Any special considerations when disconnecting/reconnecting the batteries for a speaker installation aside from what is mentioned in the owners manual regarding relearning the brake position and idle/fuel trim? Thanks, Todd |
