Wheels & Tires Wheel Help!!
I was trying to rotate my grils wheels yesterday after fixing a flat. I could not take off the rear wheels no matter what I tried or how hard I kicked the rim to try and break the seal loose. I got the lug nuts off easy but wow I have never seen a tire so stuck. I could not remove it at all no matter what I did. I had to hang my head and replace the front tire as I never was successful in removing the rear ones. .
Has this happened to others? Anyone, could you help me solve this problem?
Thank You for the help
No matter what any wheel dealer tells you. I think if you find a good wheel repair service in your area and You know instantly when it happens. In my point of view you picked a good wheel repair service, then you will be satisfied with the end results.
Regardless of what any wheel merchant lets you know. I suppose provided that you discover a great wheel repair benefit in your general vicinity and You know in a split second when it happens.
In my outlook you picked an exceptional wheel repair administration, then you will be fulfilled with the deciding effects.
Curated Content Editor
May 8, 2014 05:00 AM
tiggerx1
17
Oct 24, 2010 10:50 AM
bbmotor
Jul 28, 2010 11:34 AM
angelai
Apr 11, 2010 02:19 PM
