solar sterling engine for the home ?
I've seen articles proposing such systems in the past but I'm pretty sure it is only a 'do it yourself' project. One challenge is the ideal working gas is high pressure helium, which is difficult to seal. Still, if you could get say a small V-8 and some high-temperature, electrically operated valves, it might be a fun project. You could use a 4-cylinder with a custom crank with all four throws at 90 degrees. Alternatively, four lawn mower engines chained together with 90 degree crank angles would work.
Bob Wilson
Bob Wilson
Curated Content Editor
Mar 27, 2014 05:02 AM
