Re: How to Blend Your Own Fuel, and Why You Should
Originally Posted by gpsman1
(Post 167850)
This thread was started to tell you it may be better for your car, your wallet, and your MPG if you used 20% ethanol or 30% ethanol. It has turned into a good discussion and has become one of the most viewed threads. So shall we keep it going?
In the news today: Portions of the corn kernels are processed for use in chips, cheese crisps and various other foods, while other portions become ethanol and distillers grains. "[/I] Exerpt from Ethanol Producer Magazine http://ethanolproducer.com/article.jsp?article_id=3971 |
Wow. I Haven't viewed this thread in a while. It was slowing down for a bit there. I was watching an ethanol discussion at UCSD and it is very interesting what they are planning on doing in the future. Although I really believe that BEVs are going to be the best solution, PHEVs that run on biofuels can help us get there. And although I support ethanol, I have stopped running it in my car, at least temporarily, because my car seemed to run choppier with E85. I am going to try a new conversion kit, which will hopefully make my car run as smooth as gas on E85 and get me better fuel consumption.
I would like to suggest you try perhaps E70 or E50, or even the more popular, E30.
Just mix your own as best you can. It does not surprise me that every car doesn't run perfectly on E85. I feel strongly that every car on the road ( electronically controlled ) will do really well with E30 and the MPG will be close to that of gas. In most cases, you need no modifications at all to run E30. :angel: -John |
(Post 168609)
Good for you! I did almost the same using a spreadsheet.
I printed the spreadsheet and put a copy under my sun visor. In the mid-west you might find ethanol as lower cost ( per mile ) than gas. The farther you are away from the corn belt, it gets more expensive. Bottom line, it will be very close to the cost per mile of gas. It may cost you a penny more, or a penny less, so cost should not be your #1 motivation. |
(Post 168654)
It may cost you a penny more, or a penny less, so cost should not be your #1 motivation. Will keep you posted! |
^ According to what we have found, E30 should get you BETTER FE than E10.
Originally Posted by giantquesadilla
(Post 168961)
We don't drive the van often, so I will have to report back later on it. |
Study by Minnesota State University says you can run a PriusI ( THS ) on E85 without any modifications, if you don't mind seeing a check engine light.
http://www.greenenergynetwork.com/me.../prius-e85.PDF Highlights: Cold starts on E85 produce slightly higher emissions, however emissions on a warm or hot engine are reduced to almost below detectable limits, more than compensating for the cold start. ( provided you do more than only cold starts every day! ) Dynomometer testing shows increased horsepower and torque: 89 Octane Gas = 65bhp @ 4500 RPM and 80 ft.-lb. torque E85 ethanol = 77bhp @ 4700 RPM and 106 ft.-lb. torque Since the Toyota traction control will not let the front wheels spin beyond 19 MPH with the rear wheels stationary, the traction control was disabled, as well as electric assist, so all horspower can be assured to have come from fuel only, and none came from the electric motor(s). |
(Post 169194)
