Alternative Fuel Vehicles Running biodiesel, E85, Natural Gas, Propane? Chat here!
HHO Booster
Old May 10, 2012 | 01:27 PM
jayrerickson's Avatar
Default HHO Booster
Has anyone ever used or heard of the HHO Booster?
Old May 17, 2012 | 06:03 AM
Default Re: HHO Booster
Ive been reading more and more and people say its a good product. But I would like to hear from some one first hand using this. Seems like it really works.
Old Jul 7, 2012 | 03:11 PM
DJWorm's Avatar
I will be installing and running a 5,000 mile test on an HHO generator in late July & August and will publish results.
Most debunkers of these systems cite a number of reasons. Most fall into these categories
1. Not enough HHO produced as they tried JUST plain water instead of an electrolyte solution.
2. Not enough HHO produced as the number of plates were too small
3. Not enough HHO produced as the applied current was too smal
4. had to use an EFIE or PWM to make the system run correct....Ie. O2 sensors had interpreted a LEAN condition and added fuel
5. Wet v dry system ?
6. HHO introduced incorrectly
The system I am evaluating is a simple 2 stage "ON DEmand" dry system that produces 6 L/min at 30 amps and does NOT require an EFIE, PWM or other add on electrical device or ECU reprogramming....only a simple 5 minute Idle ReLearn procedure.
Sorsha
Apr 7, 2010 01:56 PM
Matthinder
Hydrogen Vehicles
May 12, 2009 01:02 PM
Tim K
Off Topic
28
Oct 11, 2008 11:29 PM
obiwaugh
Off Topic
Apr 6, 2008 02:44 PM
Freeze
Jul 30, 2006 09:07 PM
