Updated FAQ with Toyota URL -- suggestions?
Hi folks,
An unofficial FAQ editor, I've just added the following URL to the Prius FAQ: I am interested in making this a living document. But I don't have much information for the Prius II, NHW20 model. If someone would like to draft some sections unque to that model, please add them to this thread. After suitable comment period, I'll put them in the main FAQ with attribution. IMHO, something about the Bluetooth-phones and/or how to make the radio 'play nice' would be a good addition Regardless, my ears and eyes are open. Thanks, Bob Wilson |
Re: Updated FAQ with Toyota URL -- suggestions?
Hi Bob,
Thank you for the link. Have you ever seen following presentations? They are placed on John's site, but they are written by Toyota engineering. Toyota Hybrid System for 1997 original Prius http://john1701a.com/prius/presentat...ntation_01.htm 2004 Prius http://john1701a.com/prius/presentat...ntation_01.htm Ken@Japan |
Thank you Ken.
I've added the links under the definitions. I'll probably go back and make it a little cleaner but they are in the right areas for now. Bob Wilson |
According to this slide Toyota was already on the ball with plug-ins when they made this.
Check transaxle oil early and replace if contaminated or discolored. Early results from an NHW11, Amsoil ATF experiment suggests an annual change or ~11,000 mi., will correspond to the worn out, 15% decrease in viscosity (31 cSt @40(C)). NHW11 uses 'Type T' and the NHW20 uses 'Type W'. Keep the filters clean or replace frequently. Fleet reports suggest the NHW11 models may need to have steering assembly checked frequently. In cold weather, an engine block heater can save nearly 100 ml. of gas due to faster warm-up. Check the throttle assembly every 50,000 miles for butterfly soot. Get a tire gage and/or fill with nitrogen. Keep the tires as hard as possible, 42/40 works for most tires but always ask. The front tires need to be 2 psi harder for proper handling and best ABS operation. that's all for now, hopefully your Faq will encourage more classics to live. |
Bob Wilson |
Originally Posted by bwilson4web
I saw that too. I also know Toyota didn't sell the US Prius with the EV button available in other markets.
http://www.toyota.co.jp/en/news/06/0613.html This is the first time I saw Toyota's official announcement about the plug-in hybrid. Ken@Japan |
Thank you Ken!
Originally Posted by ken1784
Toyota announced the plug-in hybrid development.
http://www.toyota.co.jp/en/news/06/0613.html This is the first time I saw Toyota's official announcement about the plug-in hybrid. Is there a Japanese version of the GreenHybrid database? Remembering the roads on Okinawa (maybe not the best example,) I was wondering if the Japanese Prius drivers are getting significantly better performance than we see here in the USA. From what I remember of Okinawa, any Prius should should get stellar performance. Bob Wilson |
Thank you Ken!
One question I've been meaning to ask: Is there a Japanese version of the GreenHybrid database? You're welcome. Yes. There is one, but members are not so many... http://eshy.s22.xrea.com/cgi-bin/nen...?category_s=20 Sorry for the Japanese only. 1st column: life time mileage 2nd column: single tank mileage 3rd column: single tank distance Ken@Japan |
Hi Ken,
This is perfect:
http://eshy.s22.xrea.com/cgi-bin/nen...?category_s=20 Sorry for the Japanese only. 1st column: life time mileage 2nd column: single tank mileage 3rd column: single tank distance Japan: 58.2 mpg - average for middle 50% (78 total samples) 58.8 mpg - median for middle 50% 3.4 mpg standard deviation - for middle 50% USA: 47.7 mpg - average for middle 50% (684 total samples) 47.7 mpg - median for middle 50% 4.4 mpg standard deviation - for middle 50% This agrees with my expectation that USA driving and traffic patterns hit the weaker performing speeds of the Prius. USA drivers tend to have more time in the MG1 transition range and at speeds higher than 65 mph. We also do not have the EV control. This tends to reduce USA Prius MPG (km/L) performance relative to the excellent Japanese performance. Thank you again for pointing us to this great data. Unfortunately, my Japanese is not up to the mark. Could you please share my thanks along with this data to the members of the Japanese Prius database? Bob Wilson |
