Electric Vehicle Forums
-   Toyota Prius (https://electricvehicleforums.com/forums/toyota-prius-10/)
-   -   Are Prius service bulletins, etc., posted somewhere? (https://electricvehicleforums.com/forums/toyota-prius-10/prius-service-bulletins-etc-posted-somewhere-2671/)
mfa-prius Jun 27, 2005 01:25 PM
I'd like to see a list of service bulletins, recall notices, etc., kept current somewhere on line. Anybody know of such?
PrimeRisk Jul 25, 2005 09:19 AM
Re: Are Prius service bulletins, etc., posted somewhere?
You can check here for all Toyota TSBs, but I don't know how to sort for the Prius only.
http://www.alldata.com/tsb/Toyota/index-issue.html
marussell Aug 1, 2005 10:09 AM
These are for 2002 Prius, if you want the details let me know which number and I'll turn in into a pdf for all to see.
C002R-03 041221 Engine/Transmission Controls - Resetting ECM Memory
EG050-04 041220 Engine - IMPORTANT Critical Oil Fill Level & Viscosity
AC009-04 041216 A/C - Sensor Inspection Procedures
EL008R-03 041007 Instruments - Fuel Gauge Inaccuracy
EG022-04 040628 Inverter Assembly - Master/Hybrid and MIL ON/DTC P3130
BO017R-03 040303 Interior - Trim Panels Loose/Fit Poorly
ST005R-01 040301 Steering - Vehicle Pulls to One Side Manual Update
SS002-03 031217 Engine Controls - O2 Sensor Monitor Threshold Values
EL016-03 031024 Immobilizer System - Service Procedures Clarification
EL014-03 031002 Auxiliary Battery - Hard Staring/Low/Dead Battery
PG001R-01 031002 HV/Auxiliary Batteries - Service/Maintenance
EG011-03 030612 Engine Controls - Master/Hybrid MIL ON/DTC's Set
EL008-03 030516 Instruments - Fuel Gauge Inclination Meter resetting
EL008R-02 030228 Keyless Entry - Transmitter Programming & Identification
EG003-03 030224 Exhaust System - Sulfur Smell
EL004R-01 030116 Keyless Entry Remote Transmitter - Programming
PG027-02 021204 Steering/Suspension - Ball Joint Inspection
AU004-02 021128 Audio System - Audio Control Knob Inoperative
EG021-02 021120 Engine Controls - Master/Hybrid MIL ON/DTC P3125
BO017-02 020930 Interior - Seat Belt Extender Availability
EG018-02 020912 Engine Controls - Master/Hybrid MIL ON/DTC P1120 Set
EG012R-02 020905 Engine Controls - Master/Hybrid MIL ON/Codes Set
EL006-02 020809 Navigation System - Identification Method/DVD Map Data
EL013R-00 020802 Electrical - Multiple Electrical/Accessory Malfunctions
EG015-02 020801 Emissions - MIL ON/DTC P1436 Stored in ECM
TC001-02 020524 A/T - Fluid Requirements
EG003R-02 020329 Emissions - OBD II Readiness Monitor Drive Patterns
PG010-02 020322 Engine Coolant - New Color
EG007-02 020322 Valve Cover Oil Baffle - Damage Prevention
SS001-02 020301 Drive Shaft - Nut Chisel Tool
PG009-02 020118 VIN Plate - Replacement Availability
PG008-02 020118 Certification Label - Replacement Availability
PG002-02 020111 Service Manual Corrections - Availability
BO030-01 011207 Windshield Wiper Blade - Maintenance and Cleaning
ST003-01 010921 Steering Wheel - Off Center
BO023-01 010914 Seat Belt Extender - Increases Belt Length
mfa-prius Aug 1, 2005 01:19 PM
I need the 2005; I think I found how to get them on Toyota's site, but it's pretty pricey, it appears.
