how far can I drive when I drive only on the elecrtical engine of a second gen model?
Hi there,
I'm looking at buying my first Prius (I'm looking at used 2004-2006 models). I have some questions: 1. Does anybody know how far I should be able to get when I drive only on the electrical engine (so really-really slow)? 2. Maybe a bit more practical: How far should I be able to get on the electrical engine seeing the battery's power go from full to half? 3. Is this a good test of battery status? 4. Any other suggestions to test battery status as a non-mechanic? Thanks! -Mike |
Re: how far can I drive when I drive only on the elecrtical engine of a second gen mo
Couple of miles off a fully charged battery assuming you're not stopping. When a lot of slowing down is involved you get some more distance out of the battery since it's charging then you can use that charge to go a little further 2. Maybe a bit more practical: How far should I be able to get on the electrical engine seeing the battery's power go from full to half? I ran into this problem when I ran out of gas (hard lesson learned about the tank capacity becoming 10% less while in very cold weather). I think I only had about half charge or so, only was able to go about a mile but that involved some hills and the cold probably was effecting the battery as well. 3. Is this a good test of battery status? No, it's difficult to make this type of test without a system that actually reads the battery consumption rate have any real meaning between a good and not-so-good battery. 4. Any other suggestions to test battery status as a non-mechanic? They have systems like CANview and such but they are expensive and takes time. I can't think of anything specific besides putting it under a load while taking out voltage and amp readings. |
| All times are GMT -7. The time now is 08:09 AM. |
