Fix for the Prius rodent problem years 2004-2009
I am in the process of manufacturing a cure for the Prius rodent/mouse problem and should have it available in the next 2 month or so. Will solve the mouse problem getting in thru the intake to the cabin A/C filter. I lost 2 filters in a month due to mice. My concern is will I have a big enough market for it. Can be installed in less than 5 minutes start to finish.
Re: Fix for the Prius rodent problem years 2004-2009
Originally Posted by donaldgrim
(Post 225978)
Don't forget that you need to mfgr a screen for the back of the Prius also. |
I am not familiar with the rear Prius problem and have address the hole in the firewall that allows access to the the cabin A/C filter problem. Where is the problem in the rear? Don Grim
Look by the tail light.. There is a rubber flap that lets out the air when U shut the doors.. The little buggers can get in there. It is just in front of the tail-lights.:P
Hello have you comepleted the fix? If so where can I buy it? |
| All times are GMT -7. The time now is 08:10 AM. |
