E10 in a Prius II
The gas station I fill up at recently switched over to E10. I thought I'd give it a try. What kind of a hit in FE should I expect?
Re: E10 in a Prius II
Based solely on the difference in energy content between ethanol and gasoline, you might see a 3% difference with E10.
Sounds about right. With E85 you can expect a 25% decrease in mileage. So with a 10% ethenol mix instead of 85% you should see a 3-4%.
unless one modifies their driving style to make up the lack of energy given to them from the beggining ;)
just modify your driving style to makeup that 3% |
