06 2nd Gen Prius Won't Start
Hi All!
I'm a new member and upon in search of help to start the Prius, i stumbled on the forum. I was going to move the car so the wife can go shopping when i got their it was making a low tone noise, like when the alarm goes off. I tried to start it and there was no jiuce at all to start it. After reading thru the forum, i was a little hesitant to jump start the car with another car, so i took a charger and let it trickle charge for 15 minutes. I tried it after the charge but there was no response. I went back to the forum and search again, and i finally found the answer that i can go ahead and jump start it from another car. I did, but it was no response at first, so i left the cables hooked on and waited for a few minutes. Then i tried it again and this time it started it up but the it was telling me that i need to park it on a flat surface and make sure that the PARK is set corectly. So after pressing the PARK and PBrake, i drove it around hoping to charge the batteries, hopefully it will start again for me tomorrow. IYO, do you think i should have the Dealer take a look at it in case i screwed something out? BTW, i jumped start thru the positive line in the fuse box area. TIA! |
Re: 06 2nd Gen Prius Won't Start
anyone has this experience?
I've gotten that message before when I tried to start the car with the driver side door open. Are there any warning lights on the dash or MFD? When you drove around, did the gas engine actually start at any time?
This is almost similar to an 07 my company bought. One recent morning it refused to start (totally dead) :( and it had to be towed away. The car was returned by the dealership several days later.
So far, we're thinking that this was an isolated case. If not, this may indicate a manufacturing quality issue that may affect a greater number of units. I hope you case is different. Cheers; MSantos |
Originally Posted by uwaku
(Post 106442)
Originally Posted by msantos
(Post 106455)
So far, we're thinking that this was an isolated case. If not, this may indicate a manufacturing quality issue that may affect a greater number of units. I hope you case is different. Cheers; MSantos Thanks all for your response. I'll post an update once i get home. |
Hey Green, any updates?
