04 Prius Smart Stop fob not working
My fob stopped working so I replaced the battery. Still didn't work, so I pushed the smart start button a few times to no avail.
After the battery is replaced, does the fob need to be reprogrammed? Or is there an engine component that's responsible? THe backup fob stopped working so I replaced the battery in both. The Toyota dealer wasn't helpful. He just said I'd need to buy a new fob for a few hundred. I cannot afford that! |
Re: 04 Prius Smart Stop fob not working
I just changed the bat. in my 06 FOB's without complications. By any chance did you turn the master switch under the steering column off? H
I played with that master switch and the fob never worked. That's why I'm wondering if it's the engine component.
Infael, When you push the lock button on your FOB's does the small red light just to the right of the lock button flash? If not make sure the new battery's are OK or maybe you installed the bat. upside down? That little red light should flash.H
I am new to the Prius, so if I did not solve your problem you may want to give PriusChat a try. Some very knowledgeable types lurk there. :angel: H
Is your 12V battery putting out 12.6 volts come morning. If not it may be time for a new 12v bat.. They normally go about every 4 years. H
Originally Posted by Harold
(Post 233408)
Originally Posted by infael
(Post 233407)
Please clarify "I played with that master switch and the fob never worked." What "never worked"? I take it that putting the key(s) in the slot allows you to start the car w/your foot on the brake, right? By "master switch", we're talking about the SKS disable/enable button under the steering column on the left side. If you're still on your original 12 volt battery, it's long due for a replacement. You can test it via http://priuschat.com/forums/newbie-f...t-battery.html. You don't have to turn the headlights on/off (bad for HIDs, if you have them), as directed. You can just switch 3x between off and the parking light position. Priuschat is a FAR better place to lurk or ask questions about the Prius than here. |
Smart start didn't work after I hit that SKS disable/enable button under the steering column on the left side. I'd hit the SKS once, try to start the car, hit the SKS again, then try again, a few times, etc.
The car works fine with the fob in the slot. I sometimes forget to pull the key when I leave my car, including at the gas station. :( If the 12V battery is the small car battery that all cars have, that was replaced ~ 2 years ago. |
I believe the button has to be set at the in [or lower] position. When the button is out[high position] then it is turned off. If everything is OK ,then you 12V is getting week?Hal
| All times are GMT -7. The time now is 12:07 AM. |
