2008 Highlander Hybrid Transmission
I have a 2008 Toyota Highlander Hybrid Limited. My question is this:
Are the transmission and the front transaxle combined into one unit on a 2008 Highlander Hybrid, or is each a separate unit? If they are 1 unit then when you change the transmission fluid would you also be servicing the transaxle at the same time? Thank you, Dadconkster |
| All times are GMT -7. The time now is 02:05 AM. |
