Electric Vehicle Forums
-   Toyota Highlander Hybrid (https://electricvehicleforums.com/forums/toyota-highlander-hybrid-31/)
-   -   Strut or strut/mount replacement (https://electricvehicleforums.com/forums/toyota-highlander-hybrid-31/strut-strut-mount-replacement-28612/)
happy highlander Feb 20, 2013 06:53 PM
Hi,
I picked up my 2006 2WD Highlander from the shop for an oil change and my mechanic recommended strut mount replacement as the ones on there now are the original ones. The car has over 114,000 miles on it and has always run beautifully. My mechanic recommended mount replacement and to reuse the strut. Any windows onto previous experiences out there?
happy highlander Feb 20, 2013 06:59 PM
Re: Strut or strut/mount replacement
I need to amend my post.. of course the struts will be replaced! It is the spring and bellows that my mechanic is recommending be reused.
MTL_HiHy Mar 15, 2013 10:43 AM
I would say you'd be fine reusing the old spring and bellows as I often reuse the strut mount on top as well (depending on the condition of the bearing). I would also suggest doing them in pairs (front or rears) and use OEM Toyota parts if you want to maintain the same factory ride you're used to.
happy highlander Mar 15, 2013 11:26 PM
I ended up replacing all 4 struts. My mechanic recommended not using Toyota struts but Kyobi instead. Thanks for posting!
MTL_HiHy Mar 16, 2013 03:33 AM
Never heard of Kyobi struts, did you mean KYB?
If so those are good as well but they tend to be a bit stiffer than stock.
