Re: New Highlander Hybrid arrived!
Help?
Originally Posted by philmcneal
(Post 190529)
When you add or remove air in the tires, you have to recalibrate your tire pressures! Check your owners manual for more information, unless you want to ignore the tire pressure light system.
Do you know of a method to recalibrate the TPMS? |
if there is no button below under the steering column, then you have to use the techstream tool scanner :S
i need more information will post when find |
