Changing CVT fluid
I have been taking some longer trips lately and although Toyota seems to think these CVTs are sealed and shouldn't be serviced my own experience has shown this to be BS. Having done it recently on mine I'm glad I did too. Make sure you only use the Toyota WS fluid from the dealer (no substitutes!!!!) The transmission should take almost exactly 4 quarts and make sure you have a fluid pump because it's nearly impossible to set up a way to gravity feed the fluid back in. As always open the fill plug first, then the drain plug (never the other way around). This is literally just a drain and fill (no filters to change at all and the fluid level is just set to the bottom of the fill hole).
Here's a great link with pics for you to follow as well. http://www.clublexus.com/forums/hybr...ial-plugs.html CVT Transmission http://www.clublexus.com/forums/atta...s-p1150603.jpg Rear Differential http://www.clublexus.com/forums/atta...s-p1150609.jpg Old vs New fluid http://www.clublexus.com/forums/atta...s-p1150631.jpg |
Re: Changing CVT fluid
holy crap...think i may look at my fluid this weekend. I agree that I wouldnt use anything but the fluid supplied by Toyota. Great post! Was the fluid from both transaxles the same color?
Originally Posted by bandit88
(Post 252760)
Those weren't my pics but the results were pretty much the same. Front transaxle (transmission) looked like the pic, rear was still like new but changed it anyway due to mileage. |
I'm just asking but are you saying the transmission only holds 4 qts of Toyota AFT WS and the same fluid but 2 qts in the rear differential? I know the pic is a lexus but I assume it's close to my 2009 Highlander Hybrid ??
Originally Posted by jaretz28
(Post 253529)
Yes, you'll want to get around 6-7 qts to do both and have some to spare. Lexus hybrid drivetrain is exactly the same as the Highlander's so those pics are what you'd see on yours too. Remember to always remove the fill plug first, then the drain plug when doing the service. |
Originally Posted by MTL_HiHy
(Post 253532)
1 Attachment(s)
Thanks for the post. I just bought my 06 Highlander w/135k and wanted to change the trans fluid. I wanted to add, that there is a fluid spout at walmart for under $4 that works well to refill without a pump. You just have to cut the hose in half so it doesn't crimp and so you can slide it into the filler hole, but the trans fluid container can slide up next to the manifold and gravity pour.
So I have a question.
I was doing oil change on my 2012 HiHy and noticed that there is a hex plug in the very transmission belly bottom. Not on the side, as circled, right dead smack in the center of the housing flat bottom area. It's in the middle of rectangular :door" bolted to the housing and appears to be the lopwermost part of housing. Yet, there is also a "drain" plug as described in the OP post. So my question is - which one actually drain plug? As one I am inquiring about IS the lowest transmission housing point. |
Originally Posted by ukrkoz
(Post 257408)
I was doing oil change on my 2012 HiHy and noticed that there is a hex plug in the very transmission belly bottom. Not on the side, as circled, right dead smack in the center of the housing flat bottom area. It's in the middle of rectangular :door" bolted to the housing and appears to be the lopwermost part of housing. Yet, there is also a "drain" plug as described in the OP post. So my question is - which one actually drain plug? As one I am inquiring about IS the lowest transmission housing point. Any chance you could take a few pics and post so we know what you are looking at? |
| All times are GMT -7. The time now is 01:31 AM. |
