Wind Noise
My '09 Camry Hybrid has really annoying driver's side wind noise with window up. At beltway/highway driving I really have to turn up radio volume. Forget quiet classical music. Dealer says nothing he can do. Anyone with similar experiences have any luck?
Re: Wind Noise
Bruce,
Check the exterior window seal for a crack or torn area. They can also get "rolled over" and create a wrinkle for wind to whistle around. The other area to check is the rear view mirror. Is there any part of the mirror that has had something happen to it? |
Re: Wind Noise
Thanks for the reply - will check out. Have done that before, but will be a bit more thorough this time.
Re: Wind Noise
I have the excessive wind noise on the driver's and passenger's (wife's) side in my '09 Camry with all windows up. It sounds like there's a leak but dealer found nothing wrong. There's also excessive road noise in the cabin on slightly rough asphalt. These noises weren't present when I drove the demo. :( I thought about adding insulation. Anyone with his problem?
Re: Wind Noise
Originally Posted by Hnlhybrid
(Post 222927)
... There's also excessive road noise in the cabin on slightly rough asphalt. These noises weren't present when I drove the demo. :( I thought about adding insulation. Anyone with his problem?
Many owners tend to add pressure to increase their mileage, which might produce the extra noise. In addition, the demo and your car might have different brands of tires Not an expert on this, however, since I go for the recommended pressure. I'm sure others who have experience on this topic will chime in. |
Re: Wind Noise
For the wind noise, try to find a local tech with a smoke machine that can go around the windows on the outside of the car while the AC is running wide open inside the car. By running the smoke around all door and window seals, you can isolate the bad seals (if any) and know where to start. Don't forget to check the moon roof seals when checking the windows and doors.
Check the window and door alignment to make sure they are correct. A window or door that protrudes or is inset more than it should be can cause increased wind noise. If one side of the car is less "noisy" than the other, compare them to see the difference. Measure the clearances to make sure about them instead of relying on you Mark 1, model A eyeballs.... If you have changed wiper blades, they can also be a source of your noise as they often have a different shape than the factory blades. This is one of the reasons I happen to like Bosch Icons for a replacement blade as they generally have very low noise. If you have changed tires, they can contribute greatly to your road noise and as Larry noted above, higher pressures will result in a harsher ride and increased road noise. This is offset by increased mileage and better turn in performance in a curve. Another area would be a change in wheels to a larger diameter or style than the factory wheels. The different designs available increase or decrease the wind noise caused by the wheel. If you continue to have too much road noise, you can add "hush mat" under the carpet to deaden the sound heard inside the car. It is a little expensive but works very well in eliminating extraneous noise. Noise reduction measures like this have been slowly reduced by the factories due to cost but are commonly added by aftermarket sound system installers. |
Re: Wind Noise
Mahalo (Thank you) for your responses. My THC came with Michelin tires which a lot of people have attributed as being one of the more quiet tires. I keep them at 32 psi. I emailed the "hush mat" company asking if there was anyone in Hawaii that sold and installed their product but I haven't received a response. The noise factor has been my only disappointment as quietness was a major reason why I purchased a hybrid.
Re: Wind Noise
Where are you located in Hawaii? Lived there for 3 years a LONG time ago on Hickam AFB and near Kaneohe marine base and up on the north shore near Poi Pounder on Oahu.
Re: Wind Noise
I live in the Salt Lake area, near the Navy-Marine golf course. Sounds like you were stationed at those military bases which are still here, strong as ever.
Re: Wind Noise
Dad was stationed there, I just went to school for 3 years.... I know the area you live in as I had a good friend whose dad was in the navy based at Pearl. They went golfing a lot and let us carry the bags... When we were by ourselves, we used to hang out around Hanauma Bay whenever we could or just north of there at blowhole.
Back then we just called "haole" as most GI kids were not very well liked (or anyone else from the mainland for that matter....). |
