Will the 2011 Lexus LS460 OEM wheel fit my TCH
Hi,
A friend is offering me his stock wheels off of his 2011 Lexus LS460. I was wondering if these wheels will fit my 2009 TCH. The specs of the wheels is: 18" x 7.5 with 45 offset. I check the tire calculator on the net and if I use a 235/45 tire on these wheels, the overall circumference wil only be 0.7% less than the stock wheels i have on my TCH (I don't want to put my odo and mileage counter awry as it is already) My question is, will these wheels fit my '09 TCH considering its offset. Has anyone in this forum tried fitting such type of wheels from a Lexus LS (or any wheels near this spec)? I cannot try thes wheels since my friend lives across the US. I was wondering if I can get your opinions before spending $ on shipping and then havig them ship back if they don't fit. I appreciate your inputs. |
Re: Will the 2011 Lexus LS460 OEM wheel fit my TCH
Your Camry needs a 40mm to 42mm offset and 5.5" to 5.8" backspacing.
The LS460 uses a 38mm to 40mm offset and a 5.9" to 6.1" backspacing. It is close enough that they should work but have you buddy send one and try to see how the tire fits on the front and rear of your car. |
