Walking away with the FOB
Just curious to know what happens when start the car and walk away from the car with the FOB on your person? I thought I heard or read the car will shut off? Not sure if that's true?
If that is the case then I wonder how remote start works on cars(more specifically the TCH) that use the FOB/push start system? |
Re: Walking away with the FOB
The car will give you 3 electronic "beeps" that essentially tell you that the car is running and you are leaving it unattended.. It will not shut off. Matter of fact, someone else without a FOB can hop in and drive away. Of course they cannot re-start the car should they power-down.
That's exactly what happens. It does not make sense at first. However, you'd hate to have a weak battery in the FOB, have it lose connection with the TCH and shut down while on the highway.
Originally Posted by Big-Foot
(Post 108963)
Thanks Randy...that's exactly what I wanted to know. |
Originally Posted by Orcrone
(Post 108966)
LOL...that's pretty funny Marc. I never thought about it like that. Can you imagine that happeneing...pure chaos LOL |
The passenger can unlock the doors and keep the fob in his pocket.
The driver who has no fob can start and drive the car, drop the passenger off along the way, ignore the chimes and "key not detected" warning, continue to park the car elsewhere and shut down the car normally. The hitch is, the car can't be locked without a fob nor can it be re-stared by anyone without one. When the passenger with the fob catches up to the car, it can be re-started normally. |
Originally Posted by vioarc
(Post 108971)
This makes sense...but I sure wouldn't drop off the only person with a FOB and go park the car. I want to be able to lock the door:D |
I haven't tried it, but can't you lock the doors manually from the inside before getting out? If so, you don't need the fob to lock the doors.
Originally Posted by klynch
(Post 109023)
Originally Posted by tnsig
(Post 109028)
Newer cars won't let you get out of the car and just hit the lock button and close the door. Typically when you do that all the doors will lock except the drivers side door. This is a safety feature that prevents you from locking your keys in the car. The way to bypass that is to go around to the passengers side door and reach across to the drivers side door and hit the lock button. Since I don't have my TCH yet I don't know if that would work.
If the fob is left in the car, it will not lock. Pretty SMART! |
| All times are GMT -7. The time now is 05:23 AM. |
