Re: snow tires
Originally Posted by spiff72
(Post 191447)
Randy,
Do you run those Primacy Alpin's all year round, or do you swap them out for summer tires? I see tirerack.com offers them right now for CHEAP. I am just wondering whether it would be OK to use them year round, or get some steel wheels to mount them on. http://www.tirerack.com/tires/tires....m=16HR6PRPA3XL I would expect that the rubber is too soft to run them in the warmer weather. I would imagine they'd wear pretty quickly if you did that. |
Re: snow tires
:sun:I have ran Nokians on all my vehicles for many years, all year round, and have had no issues in dry, wet, or snow conditions in upstate NY. I currently have the Nokian WRs on my Grand Cherokee, Acura, and TCH. On my TCH, I obtain 38-40 mpg and in the winter around 34-36 mpg. They are winter / snow rated (mountain and snow flake symbol) and are designed to run year round. They have deep treads with many sipes, but very low noise. Good luck in your selection.:D
Re: snow tires
It has now been about a month, 15,000 kms on vehicle, running 0w20 mobi one, previous best tank was 5.3/100 km and yesterday I got 5.2/100 on a tank, outside temperature about 48-50 F. I have tire pressure at 42/40 as these are xl tires with max pressure of 51 psi.
Overall I am quite impressed with these michelin winter tires. |
Re: snow tires
For you guys swapping out to steelies for the winter what do you do about the tire pressure monitoring system?
Re: snow tires
Originally Posted by Eride
(Post 193068)
Re: snow tires
Really? I am in Calgary and was told by the dealer if I want new rims and tires I need to purchase new TPM's for each wheel at a cost of over $100 each so as not to trigger the sensor.
Re: snow tires
no tpms in canada only a us regulation being through toyota canada on my 2009 on this issue even though the manual says you have one
Re: snow tires
(Post 193073)
Re: snow tires
Good to know, I looked for the button before but couldn't find it. Thanks guys.
Re: snow tires
on the canadian model you can see the place where the button is supposed to be in the glove box, however it is blank, I have also verified this by removing my tires from the factory rims and they are standard air stems.
Sorry not in Canada at this time. |
