Smart keys Programming problem, please helpppppp :-(
Hi all,
im working with smart keys programming months ago, i have a big problem now a need your help, I have bought 15 used Camry Hybrid Smart Keys(HYQ14AAB) from ebay, different sellers, all keys supposed to be tested, when i program the keys using techstream ( after doing reset since all keys are used) the car detect some keys and some others car dont even see, 4 keys are programmed immediately on any car and another 11 refuse to program and all cars wont see when i stick the fob to the start button during the programming procedure, i checked and replaced the batteries but no joy, the led light when pressing the keys and freq is ok :confused: any help is appreciated. |
Re: Smart keys Programming problem, please helpppppp :-(
1 Attachment(s)
Check out this manual section.
Originally Posted by dg370
(Post 230941)
I suspect that you can only have x number of key fobs registered to the system and at that point no more keys can be registered. I would not assume that the fobs are bad.
OH wait the manual says a maximum of 7 keys can be registered. RTFM
To verify all key fobs you will need to un-register key fobs before registering additional key fobs. Be careful not to erase all or you will have a bigger problem.
(Post 230944)
you are right, camry hybrid accepts up to 7 fobs, i always do reset which erase all keys registered and registering only two keys, the customer original key and one of my keys, sure the 11 fobs are not bad, if two or three i'll say maybe...but 11 are too much, there is a small secret or tip to make the car see these fobs |
any solutions guys? problem still exist
1 Attachment(s)
Quote "you are right, camry hybrid accepts up to 7 fobs, i always do reset which erase all keys registered and registering only two keys, the customer original key and one of my keys, sure the 11 fobs are not bad, if two or three i'll say maybe...but 11 are too much, there is a small secret or tip to make the car see these fobs"
Are you following the procedure that I posted? If you erase all keys registered then you will be purchasing a new Certification ECU or ID code box. |
(Post 231680)
| All times are GMT -7. The time now is 01:29 AM. |
