Rear seat trunk release
My rear seat trunk release cable is hanging down. Can some one let me know how and where it's supposed to be attached. Thanks!
Re: Rear seat trunk release
Yeah, up on the rear shelf underbelly.
THE BEST CAR IN THE WORLD, and they sill didn't fix THAT? Shinjirarei!!!! http://i302.photobucket.com/albums/n...7-29142614.jpg |
put some super glu on it, or it will be coming off the bracket almost every time you load your groceries and barely touch it with a bag. What a shame.
Those stupid little things.... Another horrible design problem with this car.
There is a "slot" in the sheet metal on the bottom side of the rear deck. The piece slides in there from the front to the rear and locks in place. We use the trunk every time we use the car and I was constantly knocking these stupid things down. You can put a little glob of silicone sealant in the "front" of the slot behind the plastic. This will keep them from sliding out. If you ever need to take them out, just remove the little glob of silicone and they slide right out. Another design problem in the trunk is the cable routing running up the drivers side trunk hinge. They routed the cabling on the "inside" instead of the outside of that arm! So, if you ever decide to cram the trunk full of gear, it rubs on what every thing you put in there and eventually ripping the cabling off the arm. Repositioning the lower cable clip to the other side of the arm cures this problem. |
don't you know that designers never drive cars they designed or, worse, fix things they designed wrong?
| All times are GMT -7. The time now is 03:55 AM. |
