NAV for Camry ?
I have a camry without nav. My question is can I get it dealer installed or would a aftermarket system make more sence??
Re: NAV for Camry ?
Right now, there is no dealer-installed OEM upgrade from a non-Nav system up to the NAV system. Your only choice is to go aftermarket install (even if you use the OEM NAV unit, which won't give you the energy monitor)
Re: NAV for Camry ?
FWIW, my SO bought a BMW w/o Nav & after seeing my Camry Nav system bought a Garmin 660. Very Impressive! Doesn't refuse to give guidance in the foothills where we live, portable, built in Bluetooth, etc. I actually like the Nav piece better than the Camrys.
Apparently the 300 series is the same without Bluetooth for much less $$. On the other hand, she left it on the dash while parking overnite in San Francisco and came back to find a smashed window and no Nav. Thank goodness for the AMEX coverage. |
Re: NAV for Camry ?
Originally Posted by flopshot
(Post 120089)
However if you decide to do that be warned you will NOT get the energy screen. |
Re: NAV for Camry ?
Originally Posted by JOE540CI
(Post 120073)
http://www.oemvalue.com/toyota2.htm I had a dealer install mine. Most US Toyota Dealers won't install a Customer Supplied part. I had to call around until I found a Toyota Dealer that would agree to do it. I also had to supply them with the installation instructions as they had no clue otherwise. Like someone else said, you will not get the Energy Monitoring Screens. Although an after market system make more sense, I really like Toyota's Hands free Bluetooth implementation which is why I went with the OEM. |
Re: NAV for Camry ?
Thanks ,JOE
Re: NAV for Camry ?
So, am I correct in saying that if we have a non-nav tch there is no hope of ever getting the energy screen unless Toyota supplies an upgrade option?
Re: NAV for Camry ?
Originally Posted by iam4pack
(Post 120152)
Re: NAV for Camry ?
(Post 120152)
I've had other nav systems but have grown to really like this Toyota system. |
Re: NAV for Camry ?
Originally Posted by WMConey
(Post 120090)
FWIW, my SO bought a BMW ... and came back to find a smashed window and no Nav. Thank goodness for the AMEX coverage.
| All times are GMT -7. The time now is 04:53 AM. |
