Electric Vehicle Forums
-   Toyota Camry Hybrid (https://electricvehicleforums.com/forums/toyota-camry-hybrid-49/)
-   -   Major Malfunction updates (!) (https://electricvehicleforums.com/forums/toyota-camry-hybrid-49/major-malfunction-updates-8696/)
Norb Jul 20, 2006 05:11 PM
My TCH has been back at the dealer since Monday 7-17 (See original post Major Mal... No roadside…). The dealer called and said it was a loose ground. They fixed it and would return it today. While on the way home from the dealership the buzzers and (!)’s came back and “China syndrome” all over again. Strike two Toyota.:angry:
lakedude Jul 20, 2006 05:18 PM
Re: Major Malfunction updates (!)
Is it a bad time to mention that my mom has a Mazda 626 with over 200k miles on it that has had no serious problems what so ever?:thumbs_up
Sounds like you need a hug.....:boy_hug:
lakedude Jul 20, 2006 05:24 PM
Sorry to hear about you problems in all seriousness. I guess you are a victim of first model year bugs. Please keep us informed as to what the problems are and what Toyota is doing to fix them....
Bumzyman Jul 20, 2006 05:47 PM
Which ground wire was loose? It might be beneficial to the other early adopters here if we checked our systems out to be on the safe side before the same thing happened. I would think a loose ground could cause some pretty big problems like power surges to other equipment on that circuit, etc.
Freeze Jul 20, 2006 07:48 PM
Norb,
What state do you live in? Check your Lemon Laws. As an example, if you lived in Washington State and your car goes in two more times for the China Syndrome, the dealer is required by law to get you a new car or buy yours back at your original cost. You have every right to be furious. Thanks for sharing.
Freeze Jul 20, 2006 07:59 PM
Opps, I see Mrimaging already mentioned lemon laws this in your other thread. Sorry for the duplication.
Orcrone Jul 21, 2006 04:44 AM
Two malfunctions, so you can mention it twice.;)
WVGasGuy Jul 21, 2006 05:33 AM
While it's an agrivation to the owner and a dissapointment with an otherwise joyful moment I don't believe a loose ground wire to be a reason for applying the lemon law or for everyone to get up in arms. It is unfortunate and if it happens to all of the TCH's then shame on Toyota, but at this point you simply have my sympathy.
Orcrone Jul 21, 2006 05:42 AM
Since they found a loose ground wire, tightened it up and it did the same thing I'm thinking the loose ground wire had nothing to do with the problem. The service tech probably found it, the car worked afterwards so they assumed it was the problem.
Most lemon laws require the same repair to be made more than twice to be enforced. So if he's eventually looking at 3 or 4 trips for this problem then I don't have a problem with him evoking it, especially with a problem that leaves him stranded and could potentially be dangerous.
Freeze Jul 21, 2006 07:22 PM
Three times to the shop for the same problem allows a customer to inact the Washington State Lemon Law, be it a loose ground wire, a light that keeps burning out, or any other issue. Orcrone is right: It's not what the problem is, it's the frequency of the problem that's key.
