Low Key Battery Warning
As most new owners, I always wondered about the life span of the key's battery (and the fear of having a dead key).
My car is a little over a year old and the car just flashed the "low key battery" warning. I try to keep the key away from charging cell phones, but sometimes I've neglected to move the key away from the (cell phone) charger. In any event, I thought I'd share my key's lifespan with the forum. |
Re: Low Key Battery Warning
Thanks for sharing. I often forget to take the key fob out of my pocket since you don't have to take the key out to start the car the old fashioned way. When I'm in a hurry I grab the spare thinking I misplaced it, only to find it in my pocket later on! Hopefully I won't deplete both of them too quickly. :P
Originally Posted by haroldo
(Post 193350)
..................................... .......but sometimes I've neglected to move the key away from the charger. ..................... "Charger" ? |
"Charger" ? If the key is within three feet of a flourescent bulb or a cell phone charger (or a few other devices that emit a certain frequency), the key doesn't go to sleep and causes the battery to deplete faster than normal. |
I believe he means his cell phone charger. Not sure why it is a factor, but I guess I'll have to keep mine in a different place now...:)
Robb:shade: |
I just noticed that a faint reddish light blinks inside of the key fob when I'm within range of the car. Anyone notice this? Does this faint blinking red light only show when NOT in sleep mode?
Originally Posted by Smilin' Jack
(Post 193356)
"Charger" ?
Originally Posted by To D Lake
(Post 193358)
I believe he means his cell phone charger...
I suspect the key would still be "valid" for starting the car, I am of the belief that the key battery is only for supplying power to the key's remote control button functions. For keys that insert into the ignition and that have thief protection codes the power for the reading the protection code comes from a powered coil inside, near, the inserted key.
Remember what happens when you walk out of Home Depot not having had the clerk "blow" the NON-POWERED product thief protection device's fuse stuck to the inside of the packaging. While those are only "present", or by default, not, passive devices the totally passive (until scanned) one under my dog's skin has a very high level, complex, code. "Batteries Not Included" Nor required. It would be pretty idiotic on someone's part to not be able to start/use a car due to the lack of enough battery charge in the "key". |
wwest,
There is an emergency start procedure if the key fob battery is dead. See the manual for details. |
I'm an expert at dealing with a dead key fob battery. After almost 2 years my battery went dead. I then proceeded to replace the battery 6 times (3 separate purchases, different brand/place each time thinking I might have got a bad batch). The battery would only last about 1 to 3 weeks after being replaced. Finally annoyed me enough to make the trip to the dealer and had the entire fob replaced under warranty, no problems since then.
There certainly is no concern over issues with being stranded just because the fob battery is dead. Opening the doors and trunk required extracting and using the metal key within the fob, which obviously is a pain doing it frequently (I'm glad I didn't go thru this in the winter when turning that little knob at the end of the key requires finger tips). Starting the car by holding the fob up to the start button worked everytime, not so much a pain since I already had to get the key out of my pocket to open the door anyway. Beyond that, some additional nuisances:
Easy to forget how super convenient this wireless key is until you have to resort to the barbaric ways of the past! |
| All times are GMT -7. The time now is 12:44 AM. |
