ICE wil NOT shut down...
Red TCH:17,000 miles, Loaded with Nav, Moon Roof, Leather...
I have been having a sporadic problem with the Ice not shutting down at a stop or at low speeds. The Battery is full charge, ICE is warm, A/C off and system in ECO mode, no acceleration. Sometimes when this happens, the ICE will stumble, similar to dieseling or missing. Other times it just idles away, Of course, my dealer says this is a normal Hybrid quirk. I don't buy it! Any one else had a similar problem, and found a fix? |
Re: ICE wil NOT shut down...
I sometimes experience something similar. There's no reason the ICE should be running (battery charged, coolant temperature at 190F, very slow speeds) but it insists on running after the car's been in EV mode for a good amount of the slower tail end of my commute.
I suspect it was running the ICE to keep something warm, perhaps the catalytic converter, after cooling down due to extended EV driving. |
That's a great thought! Unfortunately, the opposite is the case for me. This appears to happen after extended highway driving with the ICE running.
The couple of times mine has stumbled between ICE on/off I have been stopped and just moved the shifter to park and back to drive and the ICE shuts right off....
It has happened to me a few times at only 2000 km so far. The engine should be warm and I have driven several miles, but the ICE insists on staying on while cruising down hill and at 40 km per hour, and even while stopped, but it usually turns off after stopping for more than a few seconds. It does seem to be some kind of quirk.
Originally Posted by Samuelrd1
(Post 122922)
(Post 122942)
[...] the opposite is the case for me. This appears to happen after extended highway driving with the ICE running.
https://www.greenhybrid.com/discuss/...ad.php?t=11537 |
Originally Posted by HybridFan
(Post 122955)
...Sounds like you're in "Stage 3a"...
Yes, it's normal. One possibly other reason this would happen is to fully charge, equalize and calibrate battery cells.
Originally Posted by Pete4
(Post 122980)
The other two things I thought of were 1) bringing the MG coolant temperature up to normal which we don't get visibility to and 2) bringing the catalytic converter temperature up to normal, which we also don't get visibility to. |
This is normal and has been discussed here numerous times.
