ICE rev??
Curious why the ice won't rev in park or neutral. No reason, I just wanted to know.
Roy |
Re: ICE rev??
Roy:
My guess is since the ICE is controlled by a computer and it's only use is to supply power to either recharge the batteries or to drive the wheels as needed, there is no need to "REV" the ICE in neutral or park. This would only hurt FE. |
Re: ICE rev??
It would also potentially destroy MG1 mechanically by over-revving it. If the car is stationary, MG1 spins at 3.6 times the speed of the ICE. This means that if the ICE gets much above 3000 rpm with the car stationary, you're getting into danger territory.
Stan |
Re: ICE rev??
Roy:
Check this link out and you can see how the system works: http://eahart.com/prius/psd/ |
Re: ICE rev??
Originally Posted by David Price
(Post 141500)
Roy:
Check this link out and you can see how the system works: http://eahart.com/prius/psd/ Thanks for the link. Pretty cool. Roy |
Re: ICE rev??
Originally Posted by SPL
(Post 141499)
Stan |
Re: ICE rev??
Originally Posted by LOL TCH
(Post 141525)
I've read of hybrid owners who "force charge" .... Although one person did report a pretty big increase in MG1 temp.
Re: ICE rev??
If you floor it, it does. At least the engine starts and revs. Never had the guts to hold it and see how high it will rev.
Later! Dang |
Re: ICE rev??
My old 2001 Honda Accord had rev limiter way back when and it wasn't even a hybrid , if you had it in park the engine would start cutting off fuel at around 2500-3000 RPM and would never go past 3000 (during driving max RPM was 6000), I guess to protect free wheeling engine from overspeeding which would be very easy with no load on it. Also TCH will spin the ICE when in park, at least mine does so in this regard it behaves exactly the same and it probably has rev limiter at around similar 2500-3000 RPM when parked.
Re: ICE rev??
LOL TCH — There's no problem running the ICE at moderate rpm in 'P', 'D', or 'B' while stationary, of course. And, if the NiMH and/or 12-V batteries aren't fully charged, there will be an electrical load on MG1 as it charges them, so that useful work will be done. However, I'm willing to bet that even then the ICE will not rev faster than 3000 rpm, and probably much less.
Stan |
| All times are GMT -7. The time now is 07:35 AM. |
