Electric Vehicle Forums
-   Toyota Camry Hybrid (https://electricvehicleforums.com/forums/toyota-camry-hybrid-49/)
-   -   Dropped TCH (https://electricvehicleforums.com/forums/toyota-camry-hybrid-49/dropped-tch-9839/)
flopshot Sep 9, 2006 10:51 PM
Dropped TCH
OK, who is going to be the first to drop their TCH? The TRD lowering springs for the 07Camry have finally hit the market. I would love to install these springs as soon as I get enough money to upgrade my wheels to 18", it's not worth dropping the car on the stock 16" wheels.
http://www.trdparts4u.com/MC-CEGI-EA.aspx
WVGasGuy Sep 10, 2006 04:51 AM
Re: Dropped TCH
And if you didn't have a sunroof you might have enough headroom to chop off the top two inches of the roof. That might help FE.
How about just dropping the front and not the rear so the car is always going downhill???
MagcamyH Sep 10, 2006 07:06 AM
Re: Dropped TCH
[QUOTE=How about just dropping the front and not the rear so the car is always going downhill???[/QUOTE]
I've gotta hand it to ya, Joe, that's a unique solution. I couldn't stop chuckling.
LThompson Sep 10, 2006 05:11 PM
Re: Dropped TCH
Thanks for the link on the TRD springs... the mod is on my list! I just did a 1+ on the wheels -- from 16's to 17's that were takeoffs from an '06 Avalon Touring. I like the TRD 18's, but wheels $$ + tires $$ was getting pricey and I wanted to go to 55 series profile and not on down to 50 series.
Here is the car with the 17's:
http://home.houston.rr.com/mazabob/Camry-with-17s.jpg
And here it is Photoshopped to lower 1.2" front and 1.4" back as the TRD springs do:
http://home.houston.rr.com/mazabob/C...7s-lowered.jpg
Sweeeet!! I need to look under and see what you lose ground clearance wise. I'm also trying to source the slightly stiffer sway bars off an '07 SE or an '06/'07 Avalon Touring (I think they are the same) -- I'll try Toyota Parts as a collision repair item. Just don't think I'll find a totaled car with undamaged ones yet... THC's rock!! :shade:
schmidtj Sep 11, 2006 04:56 AM
Re: Dropped TCH
Originally Posted by flopshot
upgrade my wheels to 18", ..
Are 16" stock wheels with stock tires any different in actual outside tire diameter than and 18" wheels and low profile tires?
WVGasGuy Sep 11, 2006 08:07 AM
Re: Dropped TCH
It depends, they won't be if sized improperly. See this link to determine
http://www.discounttiredirect.com/di...foTireMath.jsp
flopshot Sep 11, 2006 11:18 AM
Re: Dropped TCH
Here is a tire size calculator where you can see the impact on the outside diameter when changing your wheel and tire sizes. Note that this calculator doesn't really tell you the impact on the width of your tires, and you must make sure that your new tires fit inside the lip of your wheel well.
http://www.miata.net/garage/tirecalcold.html
Rcommander Sep 11, 2006 02:39 PM
Re: Dropped TCH
You're funny!:D
flopshot Sep 11, 2006 03:18 PM
Re: Dropped TCH
The first 07Camry bodykit has also hit the streets, to further make your TCH aerodynamic and improve FE. it's similar to the SE bodykit. I think in the name of research, you should all pitch in $10 each and send me the money to purchase this bodykit, and I will install it on my car and give everyone some detailed feedback. Paypal will be accepted.
:D
http://cgi.ebay.com/ebaymotors/GROUN...QQcmdZViewItem
dalerb Sep 11, 2006 03:25 PM
Re: Dropped TCH
:D
To me these kits always have the effect of giving the car an American, 1990's GM look with all of the bolted on plastic on the lower panels:
http://images.consumerguide.com/auto...9171990107.JPG
Well, OK, maybe not that bad, but still... ;)
