coastal lockpick2 out for camry dvd input screen unlocked
Re: coastal lockpick2 out for camry dvd input screen unlocked
hooked it up. All screens unlocked on nav. Video input to nav screen. Easy install.
Does it unlock the 10 digit limitation of radio song titles also (specifically sirius)?
How does it install? Do you have to remove the nav unit? Thanks in advance. Hal (Ron) |
It attaches to back of the nav unit, plug and play. I don't know about the Sirius question, I can check when I get home in the manual they supplied.
Does plug-n-play mean you don't have to remove the nav unit? Sorry, it is not clear to me from your answer.
Hal |
Well, I said you have to attach it to the back of the nav unit. If you can do that without removing it, you are a better man than I.
The website says we can have CD or DVD's in the changer!! I never knew I could put DVD's in there? There was never an option to buy a DVD changer in the '07!?
This head unit is used by other models with that option. If someone can tell me how to post pictures I'll show some.
If you click on "Post Reply" (don't use the Quick Reply text box), it will open another window which will have all the icons you see on MS-Word. You can click on the "Clip" icon as you normally do in Word.
5 Attachment(s)
here are some pics hopefully
| All times are GMT -7. The time now is 03:12 AM. |
