Camry suddenly loosing oil
A few months ago our 2007 started making a ding sound when turning corners. Took it to the dealer and they said dipstick did not hit oil. We thought our local mechanic had botched our last oil change. No problem for a while, checked it once a week. Then took it in for maintenance again today and no oil again. Dealer says $3000-4000 to fix. We have almost 200,000 miles on it. Anyone had the same problem or know what could be going on.
Re: Camry suddenly loosing oil
Is the engine leaking oil or burning it? For the price mentioned by your dealer, I would hope he quoted installing a new engine but without knowing a bit more than you have given us, it would be impossible to tell you anything.
By the way, you should check the oil in your car every time you fill the gas tank or every 500 miles. |
Well, the dealer was not very specific about what the problem was other than no oil and not very specific about what repair might be necessary, other than the cost. Seems like they could have seen more on inspecting the car. They want us to bring it in every 1000 miles, but we live an hour and a half from any dealer. I don't think it is burning oil, but it is not my car and I don't drive it, except today to get it to the dealer for the oil change. It is my husbands car and he just had cancer surgery so I am kind of out of the loop. He was checking it once a week until he had the surgery and there was no problem. I will get underneath it tomorrow and see what I can see, and put some newspaper under the engine and see if I get any drips.
You are not the only one. Some have it worse than others. It is a common problem and one of those things that Toyota "knows about", but is not willing to fix unless numerous documented complaints are made. They are several folks that have actually had their entire engines overhauled by Toyota for oil consumption.
I forget the details... Something about small passages getting plugged or something along those lines. Ours has always used a little oil and I check it weekly, because I am aware of the problem. I change our oil every 7500 miles and over those miles, I need to add an additional quart to keep it from running down to the low mark. We are about to hit 200,000 as well and the oil consumption has been about the same since we have owned it. |
Originally Posted by litespeed
(Post 251979)
I forget the details... Something about small passages getting plugged or something along those lines. Ours has always used a little oil and I check it weekly, because I am aware of the problem. I change our oil every 7500 miles and over those miles, I need to add an additional quart to keep it from running down to the low mark. We are about to hit 200,000 as well and the oil consumption has been about the same since we have owned it. To the OP, the mechanic is probably quoting you to just replace the engine, which is something I personally wouldnt do on a car with 200,000 miles on it. No sense in spending more on a repair than the vehicle is worth. My advice would be that unless you can find the source of the leak, Id fill it up with oil, drive it to the dealership and trade it in. |
Originally Posted by Shogun
(Post 251984)
The issue you are referring to was on Corollas, not Camrys.
To the OP, the mechanic is probably quoting you to just replace the engine, which is something I personally wouldnt do on a car with 200,000 miles on it. No sense in spending more on a repair than the vehicle is worth. This "overhaul" was just done on a Camry TCH that was monitored for oil consumption over on TN. Not the first one either.... The TCH "is affected".... Edit: http://www.rav4world.com/tsb/2011/T-SB-0094-11.pdf |
(Post 251984)
To the OP, the mechanic is probably quoting you to just replace the engine, which is something I personally wouldnt do on a car with 200,000 miles on it. No sense in spending more on a repair than the vehicle is worth. My advice would be that unless you can find the source of the leak, Id fill it up with oil, drive it to the dealership and trade it in. http://www.rav4world.com/tsb/2011/T-SB-0094-11.pdf |
I doubt that the TSB problem outlined is what is happening to this engine. With no problem for 200,000 miles and a sudden start to oil loss, there is either a major leak or something happened in the engine (cracked ring, blown head gasket, etc..).
Originally Posted by GeorgiaHybrid
(Post 251989)
And it DOES affect the Camry. Don't really care either way. Just posting facts. |
Thanks for all the discussion. At the risk of sounding like a dumb woman (and I am not-I know the answer to this question on my car), how does the Camry hybrid tell you the oil is low? It is my husbands car and he just had surgery, so I don't want to ask him, but I know that the only way we knew the oil was low was a ding sound and a quick flash message when turning. This time their was no ding or message. I am used to an oil gauge. :confused:
